hydraulic valve adjustment - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2012, 05:30 PM
57halfton's Avatar
I just finished installing a new GM 290 hp 350 in my 57 Chevy pickup. I got it running and broke in the cam as per instructions, set the timing and and drove it around the block a few times. I want to check the valve adjustment and the paper work and spec sheets I got with the motor says zero lash + 1/8 of a turn more, this seems odd to me. Everything iv'e seen before says 1 full turn , I usually go a 1/2 turn on engines iv'e had before. Spec sheet says 1/8, should I stay at that or go a 1/4 to a 1/2 turn preload ?
Also the spec sheet says HEI distributor with 10 degrees initial advance with a total of 32 degrees at 3000 rpm and no vacuum advance just mechanical ????? What do you guys think ?
Gene
Name:	Misc pics 002.JPG
Old 01-06-2012, 05:39 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I alway's go 1/4 to 1/2 myself alway's seemed to work well for me.
As far as the timing goes is that where you set it at and if so how did it do ?
You can alway's tweak around with the timing till it hits the sweet spot for you. JMO
Cole
Old 01-06-2012, 06:35 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Gene
Use the factory recommendations on the lifter preload. The ignition timing recommendations are out to lunch.
A thread that may help- No vacuum advance needed?
Old 01-06-2012, 07:02 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
As far as rockers 1/2 turn is a good place for them works for me anyhow. GM most likely does not want anyone to over do it and break something so they go easy on the adjustment turns.
From what I know, GM Cam on that 290HP is too aggressive, it is over cammed. I would adjust timing at (no vac adv) 4000 rpm and set it at 36 deg total, then let it idle. Adjust the carb idle and mixture with vacuum gage, set rpm and check the timing, take a reading. It should be no lower than 14, I think 10 is too low for that 350.
If the base timing is 14 16 18 20 so be it, your done with mechanical timing and base timing other than the springs for the rate.
If you cant get the base timing over 14 without exceeding 36 Deg total BTDC @ 4000 rpm, then limit the mechanical advance
Is this the HEI dist that came with the 350? Curious to know all about the amount of mech and vacuum advance it came with.
Add your vacuum advance on manifold vac and take a timing reading at idle. Adjust idle for RPM. Adding vacuum advance at idle will help that cam/engine run better.
Figure out what that vac adv is adding, if the total, total base+mech+vac adv is over 50 deg BTDC you need to limit the vacuum advance.
Old 01-06-2012, 07:04 PM
eloc431962's Avatar
Wiki Edits: 37
Mark is correct about the factory settings i would run it like that for awhile then make some changes later or when you feel they are needed. JMO
I usually do actually start out with 1/8 but i usually end up with at least 1/4 to 1/2 before it's done. IMHO
Cole
Old 01-06-2012, 07:06 PM
eloc431962's Avatar
Wiki Edits: 37
Add your vacuum advance on manifold vac and take a timing reading at idle. Adding vacuum advance at idle will help that cam/engine run better.
^^^^Good point.
Cole
Old 01-07-2012, 12:58 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Cole
My thoughts on why they say to nearly "zero lash" that particular engine/cam combo has to do w/using that cam w/basically stock springs. The weak springs can allow the lifters to pump up and if there's enough preload this pump up effect will severely limit RPM and power. The factory lifters don't have the internal C-clip pushrod cup retainers, so they shouldn't be actually zero lashed, hence they say to use the minimum amount of preload that will keep the p-rod cup/piston from hitting the retainer clip.
There are vendors like Pace Performance who say that 34 degrees total timing should be used- much closer to what that engine actually needs, IMO. Giving it enough initial timing (14-16 degrees or thereabouts) along w/a vacuum advance supplying about 10-12 degrees timing at light throttle cruise will give you an engine that will be much better to drive and get better mileage to boot.
Old 01-07-2012, 12:05 PM
57halfton's Avatar
Well it seems that after reading other posts that my engine choice wasn't a good one. I am going to adjust my valves as recommended without the engine running then move on to the timing. Is there anything I can do with the distributor to wake this turd up some ? Did I post this thread in the wrong place ? Why was it moved ?
Gene
Old 01-07-2012, 12:47 PM
techinspector1's Avatar
Wiki Edits: 326
Excellent info Mark, thanks.
Richard
Old 01-07-2012, 04:00 PM
eloc431962's Avatar
Wiki Edits: 37
Richard
Yes it is Richard.
Cole
Old 01-07-2012, 05:37 PM
57halfton's Avatar
In another thread it seems that the thinking is that the cam is to big for the compression ratio, to much duration for 8 1/2 to 1 comp. The cam that is in it is .450 / .460 lift and 222 /222 duration @ .050 lift. The heads are 76 cc chambers w/ 1.94 intakes and 1.50 exhausts. My pickup weights about 3250 lbs. with a 350 turbo trans w/ stock converter and a 3.08 rear gear. I just want it to be a good driver for around town and out on the hiway.
So now i'm thinking a cam change may be the thing to do, something with less duration and maybe more vacuum.
What do you guys think ?????
Gene
Old 01-07-2012, 10:37 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Gene
Seems you have two threads dealing w/the cam now. Hopefully the replies won't start to get too confused being posted in two places.
Anyway, Techinspector1 has compiled a Wiki page on cam to CR compatibility, located HERE.
We see that a cam having 222 degrees duration @ 0.050" lift is better used on an engine having about 10:1 static CR. We can also see an engine having 8.5:1 SCR is better served by using a cam w/ about 194 degrees duration @ 0.050" lift. There is some fudge room here, but using a 222 degree cam w/8.5:1 SCR ain't gonna make a world beater, and that's a fact.
Personally I do not make specific camshaft recommendations. I'll give you info needed so that you can make an informed decision for yourself (one of those "teach a man to fish..." kind of things), or just ask and someone here will feed you a cam that will make you happier than the cam you now have.
Old 01-07-2012, 10:53 PM
57halfton's Avatar
Thanks Cobalt , I will check techinspector's wiki page. I was thinking Monday I would call some cam manufactures and talk to their tech people and see what they recommend. I read the other thread I believe you posted and was reading what Oldboogie said, thats why i'm fishing in 2 threads.
Thanks , Gene
Old 01-07-2012, 11:34 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Comp Cams has a program that you might get a kick out of using. It's HERE. Basically you input the engine and vehicle specs and it makes a recommendation based on your input.
Giving the cam company techs a call would also be a good place to start.
Valve adjustment/ Hydraulic lifter? jason777 Engine 10 09-24-2011 02:28 PM
valve adjustment on a ford 302 with hydraulic cam davidgroot562 Hotrodding Basics 2 09-02-2011 07:20 AM
sbc hydraulic valve adjustment hottrodz Engine 10 12-16-2006 11:46 PM
Hydraulic valve adjustment? HotRodMan Engine 3 10-02-2006 10:49 AM
Hydraulic Valve Adjustment bandar93001 Engine 14 07-01-2004 07:02 PM
