Hydraulic valve adjustment?
I have done some research on adjusting valves in a 350 engine with a hydraulic cam and I am getting several answers. Adjust rocker nut while valve is closed to zero lash, then tighten an additional 1/4 or 1/2 or 1 turn. Which is it?
What are most of you doing with good results? |
It sometimes depends on the lifter manufacturer or cam grinder. I usually start with 1/2 turn and if I get chatter I go another half until its 1 turn.
Some lifters will hold the valve off the seat at 1 turn, but a vacuum gauge and your ear will tell you that. |
I have been doing it a little different the last few years.
I take the push rod between my index finger and thumb and turn it while tightning down the rocker nut. I tighten it down until I am just barely able to turn it with a little pressure. This will get you to exactly 0 lash. |
| TH350 Manual Valve Question | Pantload | Transmission - Rearend | 6 | 02-19-2006 01:48 PM |
| Valve lash adjustment, Now I'm confused? | Jag Daddy | Engine | 5 | 04-15-2004 11:27 PM |
| Cam Help | black66 | Engine | 3 | 05-12-2003 06:15 PM |
| chev. valve adjustment ( help fast ) | wrenchturner | Engine | 4 | 04-01-2002 05:18 PM |
| 350, valve lash adjustment | kenrodp | Engine | 1 | 11-13-2001 06:14 PM |
