hydraulics help - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-18-2010, 07:08 PM
hydraulics help
i recently bought a 79 malibu that has hydraulics on it the kid i got it from put trans fluid in the pumps and now the front cylinders are leaking so i was thinking about switching it back to the stock coils and shocks BUT they cut the shock mounts off when installing the hydraulics how safe would it be to make new mounts for the shocks if i decided to do this i like the hydros but they ride like crap
Old 11-18-2010, 10:41 PM
Last journal entry: day # 6 1929 ford wheel and body mach up .
criusers
atf is red so you can see yor leaks ? as far as the ride did they mount the cylinders srtaght to the frame or did they mount with springs simler to coil over shocks ? as for the leek a litle brake fluid will work wonders
hydraulics prob. jesse01 Electrical 2 08-26-2005 05:37 PM
Hydraulics vs. air ride flamedfordbronco Suspension - Brakes - Steering 16 01-24-2004 08:46 PM
LowRider Hydraulics EazyDuzIt102 Suspension - Brakes - Steering 16 11-15-2003 10:08 PM
Hydraulics HELP! EazyDuzIt102 Engine 7 05-22-2003 07:39 AM
hydraulics Impalar_67 Suspension - Brakes - Steering 1 05-16-2002 07:57 PM
