hydro boost ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2011, 08:44 PM
hydro boost ?
My truck has hydro boost from a mid 90s astro. It has worked great, till it started leaking. My pick a part has a **** load of astros with hydro boost, for like 15 bucks. However theres is a full size van with hydro. Is there a difference in these units in output are is hydro boost hydro boost.
Old 11-08-2011, 05:20 AM
SSedan64's Avatar
Most of the differences are in the Piston size of the Master Cyl., Pump output Pressure and Pedal ratio.
Hydro Rebuild Kits can be found fairly cheap on Evilbay sometimes.
http://www.ebay.com/itm/Hydro-Boost-...item2eb8e97546
http://www.ebay.com/itm/Hydro-Boost-...item256906c319
This is one of the best Hydro Operation, Diagnosis and Repair articles I've found.
http://www.brakeandfrontend.com/Arti...t_systems.aspx
Old 11-08-2011, 06:01 AM
thanks for the artical good info. I saw the rebuilds on ebay. just the pic a part boosts are cheeper and no taking apart.
Hydro Boost install pnt4u2 Suspension - Brakes - Steering 1 03-25-2011 08:47 AM
hydro boost goshawks00 Suspension - Brakes - Steering 2 08-12-2008 09:10 AM
Hydro boost brakes............. Red Grant Suspension - Brakes - Steering 6 03-10-2007 12:03 AM
Hydro-boost noise Muley Suspension - Brakes - Steering 1 04-28-2006 10:34 AM
Hydro-boost Brakes? Bill Ford Suspension - Brakes - Steering 11 08-17-2005 03:31 PM
