Hydro boost brakes............. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2007, 02:27 AM
What's the advantages of hydro boost brakes?
Old 03-08-2007, 08:43 AM
powerrodsmike's Avatar
Wiki Edits: 161
I could see a hydroboost unit as taking up less space on a firewall or under a floor, the assist is more consistant and not dependant on engine vacuum.
You can also get alot of assist for the package size, if you compare it to a vacuum booster of similar assist capabilities.
Hydroboost is an excellent alternative for a big/heavy car with a big braking requirement.
I would consider it for any application that needed power steering, as the pump is already there.
The unit itself is kind of fugly though and making all that plumbing look good in a show car is a pain. I've seen it done, but it isn't as clean looking as a vac booster.
IIRC you are building some kind of armored car with a big motor and big brakes. You could probably benefit from hydroboost.
Hope that helps,
Mikey
BE different....ACT normal.
Old 03-08-2007, 09:35 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
also be good for cars with big cams and little vacuum
Most aftermarket boosters want 18" of vacuum for proper operation
Bryan
Old 03-08-2007, 04:19 PM
Diehard gearhead
They are great when space won't allow a vaccum booster, great for big cams with low vaccum, the bad is they require power steering if you don't have it already.
Mike
Old 03-09-2007, 01:18 AM
Thank you to all, I kinda suspected as much for the pros of hydro boost, but I was looking for cons ( in strictly functional sense, not for the image).
Old 03-09-2007, 10:22 AM
bet on black's Avatar
hotrodder 4 life
they are heavier, i don't know by how much though
Old 03-10-2007, 12:03 AM
Last journal entry: '66 Chevy II Nova
Read this! Go half way down the page!
http://www.geocities.com/casanoc/
John
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 06:29 PM
Brakes locking up in non ABS system nprfan Suspension - Brakes - Steering 9 08-24-2005 12:37 PM
Hydro Boost brake system BLOWN 1100 Suspension - Brakes - Steering 1 07-12-2004 12:23 PM
Hydro Boost / Power Steering Plumbing bg Suspension - Brakes - Steering 1 06-20-2003 12:47 PM
Hydro Boost brake systems??? bg Suspension - Brakes - Steering 3 10-20-2002 05:00 PM
