Hydro Boost install - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2011, 07:51 PM
pnt4u2's Avatar
Hydro Boost install
I have a hydro boost system out of 84 Chevy p/u 6.2L installed in my 54 Ford Panel truck. I am re plumbing the system. Can I rotate the Hydro boost unit 180 degrees, turning it upside down, as long as I keep the brake reservoir upright? The bolt hole pattern is the same, 4 bolts square. This will give me some additional needed clearance.
Old 03-25-2011, 09:47 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
Yes, you can clock it anyway you need. Makes for a clean install
Rich
hydro boost goshawks00 Suspension - Brakes - Steering 2 08-12-2008 10:10 AM
Hydro boost brakes............. Red Grant Suspension - Brakes - Steering 6 03-10-2007 01:03 AM
Hydro-boost noise Muley Suspension - Brakes - Steering 1 04-28-2006 11:34 AM
Hydro-boost Brakes? Bill Ford Suspension - Brakes - Steering 11 08-17-2005 04:31 PM
Hydro Boost brake systems??? bg Suspension - Brakes - Steering 3 10-20-2002 06:00 PM
