Hydro Boost / Power Steering Plumbing - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2003, 08:08 PM
bg's Avatar
bg bg is offline
Just double checking on this to make sure i have all the plumbing to the correct port!!!
From the power steering pump to the SMALL port on hydro boost and then from the LARGE port on hydro boost to SMALL port on the gear box. Then from the LARGE port on the gear box to a "T" for a return line back from the Hrdro and gear box to pump!!!!!
If this all sounds correct please let me know ............
Bg:p :p :p :p
Old 06-20-2003, 12:47 PM
deuce_454's Avatar
you are absolutely correct, the high pressure fitting on GM gears and hydraboosters i sthe same size, and so is the low pressure one, I have that same strup on my 66 impala, and i predict that you will love it...
