Hydroboost? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2009, 05:11 PM
Hydroboost?
Hey guys
I'm looking to put a hydroboost unit in the truck I'm building.
Just curious if there is any real difference between one from a 1995 astro van and a 2003 chevy truck. I can get either one for the same price from the wrecking yard that has them.
Will they both bolt up to a typical chevy master cylinder?
Thanks for any info.
Kim
Old 04-20-2009, 06:12 PM
fast68's Avatar
likes chevy trucks & boobies
Old 04-20-2009, 07:32 PM
Thanks fast68
The master cylinder I have would fit a 72 vette with 4 wheel disc brakes.
The mounting of the hydroboost to the firewall doesn't concern me because it is going in a 57 chevy pick up and will be mounted below the cab on a custom mount. I guess I could get the master out of the truck also but I'm not sure if it had 4 wheel disc as the rear is already gone.
Kim
Old 04-20-2009, 09:09 PM
i do not see the hydroboost from the astrovan being a concern. it is used all the time in the minitruck world on s10's. and the master cylinder that you have for the vette is the same style as the "universal" hotrod gm ones correct? if so it should bolt right up.
Old 04-20-2009, 11:00 PM
The astro van unit will bolt right up but the truck one is a lot newer so i would prefer it if it will bolt to my master.
Kim
99 chevy hydroboost problems dhspyder Suspension - Brakes - Steering 1 11-20-2009 06:59 PM
hydroboost bypass OUTLAW00 Suspension - Brakes - Steering 8 10-10-2008 10:15 PM
Custom Hydroboost on '69 Torino blacksunshine Suspension - Brakes - Steering 8 08-03-2007 09:44 AM
Hydroboost heavy steering propaneburner Suspension - Brakes - Steering 4 12-11-2006 09:06 AM
More hydroboost questions!? 69ChevelleAddict Suspension - Brakes - Steering 8 07-16-2006 06:55 PM
