Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hydroboost on a 1969 Camaro
Old 11-18-2012, 03:28 PM
LATECH's Avatar
LATECH LATECH is offline
Last journal entry: New Gas Tank
[QUOTE=bodiebyles;1612759] I broke the rear line loose to change out the adjustable protional valve and the fluid was was gone out of the front of the mastercylinder?? Is it hooked up backwards??/QUOTE]
Yep. chances are real good that all the fluid leaked into the rear brake area. Pull the wheels to see. The residual pressure valve , holds pressure against the cups in the wheel cylinders to keep them sealed tight, without it, they will leak out.
Sounds like your master is hooked up backerds.
Fact is stranger than Fiction
