Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hydroboost on a 1969 Camaro
Old 11-19-2012, 06:42 PM
bodiebyles's Avatar
bodiebyles bodiebyles is offline
Rear end checked out ok!! It is a 4 wheel disc car. I think it has the wrong propotioning valve. They sent two. I'm going to put the other on it. and switch the lines. I lost the fluid when I took out the adjustabel propotioning valve. I put a valve back that was in it. I think its a residual valve that I don't need anymore. Going to take it out. The car had disc in the front and drums in the rear. Had a Vacume boost system. If I can't get this Sh$$ to work it might go back on!!!!
