hydroboost on 99 suburban - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2009, 07:52 PM
i have a 99 3/4 ton suburban with a 454. it is leaking power steering fluid from the hyrdoboost unit where the brake master cylinder/resevoir mounts the the hydroboost unit. is this a common problem? how is it fixed?
Old 07-08-2009, 08:59 AM
Sounds like time for a rebuilt hydroboost. I had to replace the one on my 99 truck a year or so ago. Not very difficult to do, but remember to take the pushrod, spring, and retainer from your old unit before you return it as a core, since you need to reuse these parts.
DO NOT ask me how I know this...
Old 07-09-2009, 08:26 PM
I've got the same problem with my 96 3/4 ton suburban, but i have the 6.5 diesel. I dont think its really a common problem tho because my truck has 250k on it and the hydraboost has never been changed. The part is kinda expensive. $180 from the parts store for an A1 Cardone part and $433 from the dealer for an oem ac delco part. And i dont care much for a cardone part. But i cant afford $433 so cardone is what im gonna have to use.
Old 07-10-2009, 01:40 PM
RE:replacement
Check out tallon hydraulics.com thay have rebuild units with one year warranity all units are tested.
99 chevy hydroboost problems dhspyder Suspension - Brakes - Steering 1 11-20-2009 06:59 PM
Installing 53 Suburban modified side glass Sly's 53 Suburban Body - Exterior 0 05-30-2009 09:31 AM
Wheel bearings on 99 Suburban 4x2 ChevyTuff Suspension - Brakes - Steering 2 09-17-2007 12:19 AM
Custom Hydroboost on '69 Torino blacksunshine Suspension - Brakes - Steering 8 08-03-2007 09:44 AM
More hydroboost questions!? 69ChevelleAddict Suspension - Brakes - Steering 8 07-16-2006 06:55 PM
