Hydroboost heavy steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-07-2006, 12:30 PM
propaneburner's Avatar
Last journal entry: Artillery wheels
Mounted a powersteer and hydroboost in a pick up rod.
But when braking the car starts to steer heavy.
Are there differend pumps(with or without hyrdoboost) g.p.m. ?
Differend pulley sizes ?
Any help welcome.
Thanks
Wander.
Old 12-08-2006, 09:55 AM
Sometimes a larger steering wheel REALLY helps ...
Old 12-08-2006, 12:34 PM
15 inch is not that small, is it ?
Wander.
Old 12-09-2006, 10:08 PM
Read this link. Scroll down to the pumps section. You may be able to increase the flow by drilling out the flow restricter.
If the brakes work fine when not steering and the steering works fine when not braking it is a flow problem and not a pressure problem that you have.
http://www.pirate4x4.com/tech/billav...ng/index2.html
Old 12-11-2006, 09:06 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
I don't know for sure how the hydroboost is supposed to be plumbed. Make sure you have the hoses routed correctly though.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 06:29 PM
Problem: Steering Rack? horvath Suspension - Brakes - Steering 64 06-15-2005 08:11 PM
Swapping to big block chevy low77ride Engine 5 09-15-2004 09:30 PM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
