Hydroboost plumbing ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2006, 01:33 PM
I located a hydroboost master cylinder that I think will work well in my '59 pickup. Can anyone tell me how to plumb the thing in. I have a power steering pump but need to know what to plumb in first . Do I go to the hydro-boost first or the steering gear? What about the pressure reservoir,where does that belong? Does any power steering pump work or is the pressure going to be incorrect. I could get the psp out of the wrecked vehicle as well if need be.The vehicle it's coming out of was hit hard in front and so it's difficult to see how it's plumbed. Luckily the collision was low enough that it missed the master cylinder assembly.Thanks Tom
Old 07-09-2006, 12:33 AM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
I put my new portable work lights together just so I can help you with your question.
I dont know what year truck you got your master cylinder from and I dont know how much they've differed over the years. What I can tell you is how the hydroboost is plumbed on my '00 Silverado 2500 and hope that it is of some help to you.
First, it appears that you'll need a power steering pump with three hose connections on it. So the one you mentioned from the wrecked vehicle is probably needed. Anyway, on my truck the pressure line leaves the pump and is run to the master cylinder. Then from the master cylinder the pressure line runs down to the steering box. From the steering box a line is routed to the power steering cooler before returning to the pump. The pressure line to the master cylinder is connected to the inside (passenger side) connection on the master cylinder while the line from the master cylinder to the steering box connects on the outside (drivers side) connection. Does that make sense? There is also a low pressure hose that runs from the master cylinder down to the side of the pump. If my digital camera hadn't crapped out I'd take a picture of it.
Hope that helps...
Old 07-09-2006, 02:35 AM
propaneburner's Avatar
Last journal entry: Artillery wheels
Check out
www.hydroboost.com
The have your answer.
Old 07-10-2006, 06:40 AM
Hope that helps...
Yes, and I believe now that the one I'm in the process of getting (from a mid 90's astrovan) is plumbed in a similar fashion. I still have access to the vehicle and so will return to retrieve the pump and cooler. I didn't get that to begin with because the vehicle was hit low in the front and I couln't see that stuff. The owner (of the yard) says I can cut away whatever I need to in order to get at the pump. I hope the mounting will not be different on the v6. Thanks for your help. Tom
Old 07-10-2006, 07:01 AM
Originally Posted by propaneburner
Check out
www.hydroboost.com
Thanks, some good reading there. I think I'll grab that PS pump from the donor vehicle just in case things don't work out plumbing wise. Tom
Old 07-10-2006, 09:56 PM
Blazin72's Avatar
Wiki Edits: 19
Let us know how the install works out. I've been toying with the idea of putting hydroboost on my 72 Blazer.
Old 07-11-2006, 06:19 AM
Will do. The one I'm using has a return line in the(brake) booster. I will have to bring this together with the return from the power steering b/4 going to the pump. Will let everyone know. Tom
Old 07-11-2006, 11:52 AM
A hydrolics service can press the oil lines for you.
Old 07-16-2006, 10:25 AM
try this link it may be helpfull
http://67-72chevytrucks.com/vboard/s...d.php?t=202888
Old 07-16-2006, 11:13 AM
The Astro van you are getting parts from will have remote reservoir for the fluid. It's pump has three fittings: pressure out (threaded metric), return from steering box (3/8" hose nipple), and supply from reservoir (5/8" hose nipple). The reservoir has two hose nipples: 3/8" for return from hydroboost, and 5/" supply to pump. Looking at the front of the hydroboost, the threaded fitting on the left is the supply, the threaded fitting on the right goes to the steering box, and the hose nipple goes to the reservoir. Let me know if you want pictures, as I have the whole setup sitting in my garage.
Air compressor unloader plumbing Dynomatt Garage - Tools 9 02-27-2011 04:45 PM
Plumbing Compressor.... PairOf69's Garage - Tools 3 12-07-2005 09:17 AM
blow through 6x2 plumbing rlackey Engine 2 12-06-2005 08:20 AM
Compressors & plumbing for spraying electriclightfoot Garage - Tools 16 11-11-2004 08:44 PM
Plumbing slider in wa Transmission - Rearend 1 10-07-2002 07:16 AM
