hydronic radiant heat- thats heated water folks. - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2006, 08:24 PM
Don't really know how to word this. I don't know much about how the hydronic radiant works other then radiant warms objects, but is the floor the best place to run the tubing or are walls or ceiling/ blower about as efficient, I was just thinking about it a little bit, and the best ventilation for a spray room would be downdraft, but if heat was under floor wouldn't you lose it with downdraft airflow. Seems the most common place its run is under floor. Just thinking about how you would use it if using in a booth, but every booth I searched and found was electric radiant heat or forced air furnace. Or how bout just if you were using hydronic radiant heat in a room with downdraft ventilation how would you do it. from the ceiling, vent out the floor? Does any one have under floor radiant heat in there shop, and how do you ventilate it? I am Just thinking about for the future, wouldn't do anything anytime soon.
Old 12-28-2006, 08:21 PM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
Typically, radant floors are great for most uses, commercial and residential. The one thing to be wary of is it's more of a slow even heat, it takes a while to warm up a concrete slab. It makes your feel warm even with a slightly lower air temperature though, so it can use less fuel. I'm assuming that if you had a spray booth, you need heated air for ventilation and the radiant slab isn't going to help much.
Putting water in the intake??? 79transam Engine 50 01-10-2006 12:23 PM
Panel warpage help? Gearhead forever Body - Exterior 8 12-03-2005 05:02 PM
over heating delsman Engine 38 09-14-2005 08:32 PM
Chrome water pump 49dream Engine 12 11-16-2004 05:17 PM
additive lowers temp in radiator,trans. and powersteering pump IHAVECHEVYPARTS Engine 4 11-21-2002 07:42 PM
