Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - hydronic radiant heat- thats heated water folks.
Old 12-28-2006, 08:21 PM
Arrowhead's Avatar
Arrowhead Arrowhead is offline
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
Typically, radant floors are great for most uses, commercial and residential. The one thing to be wary of is it's more of a slow even heat, it takes a while to warm up a concrete slab. It makes your feel warm even with a slightly lower air temperature though, so it can use less fuel. I'm assuming that if you had a spray booth, you need heated air for ventilation and the radiant slab isn't going to help much.
