Hyper Pistons with a turbo? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2013, 02:52 PM
Anyone done this before? I got a set of brand new kb silvolites dish pistons laying around the garage, wondering if its worth running on a low boost engine something around 5-7 psi maybe 10ish. cr with the heads sould be in the 8:2something area. I can get a part number later today.
Old 02-11-2013, 03:11 PM
T-bucket23's Avatar
Wiki Edits: 26
If you want it to live you should run forged pistons. Starting at 8:2 is fairly safe if you keep the boost down. If you detonate them they will break.
Chet
Old 02-11-2013, 03:28 PM
Yeah I've heard these pistons tend to shatter pretty easily.
Old 02-11-2013, 03:34 PM
I forgot to mention they are for a 383 stroker.
Old 02-11-2013, 03:36 PM
F-BIRD'88's Avatar
Yada Yada Yada
Detonation will bust a forged piston too. It just fails differently.
Most all OEM cars that are turbo charged or supercharged use a cast or hyper piston.
If you hammer on any piston hard enough-long enough it will fail.
The boost is not hard on a piston. Detonation is. A failed piston always means you did something wrong.
Many many sucessfull supercharged-turboed motors have been built and run with KB hypers.
If you try hard enough you will find a way to bust one.
Can you build a turbo motor that won't hammer it self to death?
Are you willing to put decent gas in the tank? there is no free lunch.
Old 02-11-2013, 03:40 PM
Run 93 pump gas, wouldn't mind doing water meth too.
Old 02-11-2013, 03:44 PM
Throw a few gallons of race gas on the weekend mixed with 93.
Old 02-11-2013, 04:02 PM
But the more I can just run on 93 and use a water meth kit the better!
Old 02-11-2013, 05:20 PM
vinniekq2's Avatar
how many turbos? are you planning on 750 plus hp?
Old 02-11-2013, 09:07 PM
Just a single, no more then 500 550. I just want a really fun street car that will run 11's and can drive it anywhere and everywhere.
Old 02-11-2013, 10:16 PM
F-BIRD'88's Avatar
Yada Yada Yada
A roots blown motor is a lot more fun.
Old 02-11-2013, 11:11 PM
You can run 5-7 psi on stock cast pistons without worry. 7 is pushing the safe limits. You can do it.
Do not detonate. Play the curve safe.
A roots is the cheapest way possible to get that level of power.
Old 02-11-2013, 11:58 PM
F-BIRD'88's Avatar
Yada Yada Yada
The only way you will break a cast piston in a blower motor is either detonation or ring end butting.
Avoid both and they will take a lot of boost.
When combustion is normal its not hard on the piston.
The top ring end gap has to be bigger with a KB piston in a blown motor.
Build and tune the supercharged engine so it does not knock under WOT boost and
the pistons will out live you.
Old 02-12-2013, 06:36 AM
How fast is fast enough?
I'm not sure why you think a roots blower is the cheaepst route, or why Fbird think that they're more fun. There are a LOT of ways to make good power, some cheaper and some more costly.
Nothing wrong with a roots blower but is far from the only show on the block.
Old 02-12-2013, 06:45 AM
To tear apart a engine , get a cam , heads is more expensive. A roots 144 is under $1000. You can easily double the output of a stock 290hp long block.
A good piston , cam, head combo cannot take that pepsi challenge.
Speed pro hyper pistons ok for circle track? maxpower_454 Engine 16 05-27-2009 06:58 AM
What endgap should I use on Hyper Speed pro 350 flattop pistons? eric32 Engine 3 02-24-2009 05:12 PM
What are the lightest SBC Hyper Pistons Double_v23 Engine 11 04-04-2008 05:04 PM
Chevy 383 What cam to run???? Also Forged or hyper pistons?? 89SDime Engine 19 02-27-2006 11:59 PM
hyper ereutectic pistons 67 stang Engine 11 04-10-2003 10:34 PM
