Hypereutectic Ring Gap?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2007, 05:38 PM
Hey guys quick question. Engine is a 383 SBC, bore is 4.030, Keith Black hypereutectic pistons. I was told these pistons require a larger ring gap because they expand a lot more. Could anyone who knows please tell me what I should have for the top compression and 2nd compression ring gaps? Right now the top rings only have about 0.015" which I am sure is far too little.
Thanks guys,
Keith
Old 11-27-2007, 06:16 PM
Jmark's Avatar
Ring gap has nothing to do with the type of piston, but with the material the rings are made of and what the application is, IE: naturally asperated or forced induction.
Hyper PISTONS usually have a very tight fit in the bore, usually .001 smaller than the bore.
To set the RING gap, you need to go by the manufacturers suggestions. Plasma, chrome moly, cast and so on, each will have a slightly different end gap desired measurement. The "rule of thumb" is .004 per inch of bore. But again, you need to use the specs that the ring manufacturer states.
Mark
Old 11-27-2007, 06:26 PM
Yea the rings are total seal and the pamphlet that came with them says 0.0045" gap per 1 inch of bore for the top ring for naturally aspirated street applications. It was the guy at the machine shop that said hypereutectic pistons will need a larger gap so that is why I am a little confused on what "larger" should be. I can do some research thanks for your reply.
Keith.
Old 11-27-2007, 06:29 PM
http://www.kb-silvolite.com/clearance_pop.php
Old 11-27-2007, 08:15 PM
King of my Man-cave.
Gap the K-B Hypers too little (as is normal for other types) and you end up with pistons coming apart at the top ring land.
tom
Old 11-27-2007, 08:59 PM
Notorious's Avatar
Hot rodder, not street rodder!
Very true. The KB hypers have special gapping requirements. Treat them like other pistons in this respect, and they'll self-destruct in short order. Consult the link above and select your gap needs accordingly. As an example, when I ran them in a NA 350 Chevy for mainly street use, top was .026" and second was .018".
Old 11-27-2007, 09:48 PM
Thanks for all the responses guys!! I have one more question since I will need to gap them now. Is there any other method of gapping rings other than the table mounted, hand-operated ring grinder?? I do not have one of these ring grinding machines and it is not so easy for me to get my block to the machine shop for them to do it so if there is any other way of doing it (basic hand file and vice?) I would really appreciate any suggestions that you experienced builders have used in the past.
Thanks guys,
Keith
Old 11-27-2007, 09:57 PM
A file works fine. Be sure and file inwards so you don't knock the coating off the outside of the ring. Use a small sharpening stone to smooth the edges where you filed.
Old 11-28-2007, 04:19 AM
bentwings's Avatar
bentwings
A new smooth file in a vise. Like above. Try to get the gap as parallel as possible. Deburr with a smooth stone.
Old 11-28-2007, 10:49 AM
Last journal entry: PICTURE TEST
rings
Mark, the KB Hypereutectic pistons do require a different top ring gap then conventional pistons. This is one time where you need to follow the piston manufacturers proceedures and not the ring manufacturers..
I am not sure what all the engine spec's are but a few things to also look at.
If this engine is on the edge for static compression/cylinder PSI vs the octane of fuel you are going to run you need to pay real close attention to detonation. I have 20 or 25 engines out there with the KB hypereutectic pistons in with only one failure. You can gap the rings correct but if you detonate the engine you WILL break the pistons. This is not a maybe it will happen. The only failure i have ever had with these pistons were due to the customer detonating the engine.
I personally have found that a top ring gap .002" over the recommended is better then on the tight side with no effects on leak down.
Keith
Need Correct Ring Gap Clearance newdad1 Engine 5 08-28-2007 03:50 PM
Piston ring end gap Oldphart Engine 2 01-06-2006 02:33 PM
ring gap with hyperuetectic pistons bullheimer Engine 5 06-04-2004 12:56 PM
KB pistons ring gap? nastynova Engine 4 03-21-2003 06:56 PM
Ring End Gap bpd411 Engine 3 02-26-2003 09:19 AM
