Outlawed tunes from outlawed pipes |
Think again!!
James -
I applaud the enthusiasm of youth, but go back and re-read Poncho's entry from yesterday. He couldn't have said it any clearer...it makes no sense. What kind of 6-cylinder do you think you'll install for 'economy' that will haul around this car with an extra 800 or so pounds of V-8 sitting in the trunk? AND, what kind of performance do you think it cvould give you? We can get excited about a twin-engined car...a hot rod, a tire-smoker, an exhibition monster. We can't fathom, though, a DD and hot rod combo like you envision. ' hate to burst your dream, but......... Whatever you tackle, though, good luck!! |
H'mmmmm.....pondering..
What if i were to put another engine drive train in the rear of my Focus... It would fit just fine with a cover...some tinkering with the shift linkage and just maybe and I say just maybe I could geti the two engines to co-ordinate with a common ECU..H'mmm just nuts enough to make work..With superchargers the Zetec will make about 250 ea for a 500hp 4wd..mega bunouts anyone... Sam
http://www.driversfound.com/scirocco/history/bimotor/
Hi twin engined cars have been tried on this side of world by many, but as some poster above stated this forum leans more towards Hot Rods. The motorsport im involved in has hundreds of twin motorbike engined cars and buggys , if you want to "stimulate" your mechanical mind then Google Autograss UK. I have owned and raced" twins" as we call them,and its never ending work allthough" big grins " Supprisingly the syncronisation is not that critical, thnk of a well worn V8 only some of the cylinders are working the others are just going along for the ride,!!!! |
This was in Hot Rod awhile back.
![]() http://www.hotrod.com/featuredvehicl...ggy/index.html Shane Edit : burnout video Last edited by Chevrolet4x4s; 07-04-2010 at 03:09 PM. |
This august issue of hot rodder has a twin engine dragster in it. scanning through it, one engine was facing forward, one backward. one flywheel was bolted to the crank snout of the backwards one and the flywheel teeth were meshed together. the engines were next to each other and clocked with the inside banks of both engines upwards. cool stuff. it ran high 8's low 9's in 1960-61. I think it was the howards car.
Two engined dragsters have been around since the early 60's
Eddie Hill's Double Dragon ![]() Double Dragon, it had a 92” wheelbase, and side-by-side blown Pontiac engines with separate clutches, drive shafts, and ring and pinions. He ran four rear slicks in open competition, and two for smokier runs at match races. Freight Train AA/GD (1959-1971) Owner: John Peters of Santa Monica, CA. ![]() Most famous and recognizable Top Gas dragster of all time is John & Bev Peters twin engine Freight Train Top Gas Dragster. From 1960 (Peters & Frank) to 1970 there were four different "Trains", each nicer and faster than the one before it. Voigt & Thompson "The Monster" ![]() Early Lions gas dragster and top eliminator standout Fritz Voigt teamed up with Thompson later on and together they campaigned this frightening, four-wheel drive and twin-engine dragster "The Monster", which later became a Bonneville record holder. I have personally seen the Freight Train and the Double Dragon race at different times. Was quite the spectacle. Never did get to see "The Monster" thought, wish I had. Thanks to Caclefest.com, CompetitionPlus.com and Draglist.com CackleFeast.com CompetitionPlus.com Draglist.com |
I have known two guys that put two engines in old VW Siroccos. You can probably use a single transmission with a differential to distribute the power, there are many pulling tractors that link 4-12 engines to a single gearbox. Only question I have is what body would you be putting this two motor set-up in?
| Painting a Metallic in pieces | Polish Painter | Body - Exterior | 18 | 09-11-2010 06:16 AM |
| Three different paint shops suggested 2 different ways of painting the car, opinions? | Ripped | Body - Exterior | 8 | 04-30-2007 02:05 PM |
| Police car engines to avoid? | staleg | Engine | 4 | 08-19-2006 06:38 PM |
