hypothetical 2 engines one car - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2010, 08:02 PM
jameshi's Avatar
71 ford high boy
is it possible to make a car to have 2 Independent engines one to run fwd and one rwd it would be a fun project would i need 2 shifters or could i just use one what would i need to do it or is it even possible what do u guys thank
Old 07-02-2010, 08:11 PM
It has been done, back in the sixties. A '66 Toronado with engines front and back. Don't know much more than that. I've had a few Toronados, and the thought crossed my mind.
Old 07-02-2010, 08:26 PM
Two8tyThree's Avatar
Last journal entry: Picture of delivery
Yeah, that Olds was the weirdest thing I ever had seen.
Twin Engine Olds
Old 07-02-2010, 10:20 PM
.....W.T.F!?
Old 07-02-2010, 11:12 PM
sickboy84's Avatar
History channel has a documental about dragracing in the 60's and they show a few cars with two engines but was a bad idea in that times cause that makes a lot of smoke so you cant see anything the first 60fts........ i dont know if its a good idea to run but sounds very funny!!
Old 07-03-2010, 12:34 AM
jameshi's Avatar
71 ford high boy
it might be funny but it will be fast
Old 07-03-2010, 04:00 AM
Barris' crew made a few cars with dual engines tv tommy Ivo had that 4 engine olds dragster, Roth made one.rob riener made one carl casper made some. i was wondering why no one in here ever tryed it
Old 07-03-2010, 05:08 AM
malc's Avatar
Living At The Speed Of Life
Dual motors double the trouble I suppose.
Old 07-03-2010, 05:16 AM
poncho62's Avatar
Wiki Edits: 5
We have a member with a 2 engine hot rod......
2 engines is one thing, but having one for mileage and one for racing doesnt really make much sense....too much weight to drag around
Most dragsters did that back then.....Tire and clutch technology was not what we have today
Old 07-03-2010, 05:27 AM
poncho62's Avatar
Wiki Edits: 5
Comments from identical thread which I deleted......
Chevrolet4x4
You could theoretically use a fwd with its present drive train then put a Jag (or BMW) which are you using? in the back seat then the transmission with the output yolk connected directly to the Jag irs. but you're going to have 7-800 lbs of dead weight there since you're only using the rear engine.
Shane
wayneooo
you can do anything if u have a bottomless bank account......no really i saw a Dodge 60's van with 2 426 hemi's in the rear bed hooked up to a reverse 4x4 transfer case
Old 07-03-2010, 06:06 AM
malc's Avatar
Twice motored dragsters.
Dual motors were a result of the nitro fuel ban.
Old 07-03-2010, 06:20 AM
DENCOUCH's Avatar
yea, they were out there
I remember a dual engined Caddy out there & it ran pretty well. I googled it & found this. Click here
Old 07-03-2010, 07:15 AM
Will I ever get it done?
Last journal entry: Hood
Hurst Hairy Olds. 442 with twin Toronado drive lines. There were actually two cars, a 66 and a 67. They were both ill handling and eventually the 67 crashed. http://hursthairyolds.com/1966.aspx
Here's a video of a lower hp, modern interpretation.
http://www.streetfire.net/video/thes...-olds_9659.htm
Old 07-03-2010, 09:35 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
How about 2 455 cube tri-powered Olds motors, fits inside a station wagon for burnout contest. The rear is from a Tornado. My friend made the exhaust system for the car. Sorry I do not have any photos of the finished car.
ID:	46561   Click image for larger version
Luv the smell of NITRO in the morning.
Old 07-03-2010, 11:36 AM
jameshi's Avatar
71 ford high boy
what would be the best motor to put in back
Painting a Metallic in pieces Polish Painter Body - Exterior 18 09-11-2010 06:16 AM
Three different paint shops suggested 2 different ways of painting the car, opinions? Ripped Body - Exterior 8 04-30-2007 02:05 PM
Police car engines to avoid? staleg Engine 4 08-19-2006 06:38 PM
