Hypothetical HEI Module/Coil Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2008, 06:38 PM
Sweet-34's Avatar
Lost In The 50's
OK.....I break down in the middle of nowhere. I have a spare Ignition Module and In-Cap Ignition Coil for my stock GM HEI. I have 12-Volts to the distributor with a test light.
Is there a way to check and know which part has failed without changing both parts?
Thanks for all information~~~~~Ron
Old 02-11-2008, 07:58 PM
31 five window
Last journal entry: grill and rear end
It is easier to keep a spare distributor and swap it out and repair it later.
Old 02-11-2008, 09:31 PM
1930u's Avatar
Last journal entry: 1930u Its just been sitting
We had a kent moore module tester back in old days at the dealership. You can also ohms test the coil. More often than not the problem was the pole piece and you have to remove the distributor to replace it anyway. In my personal car I used to always carry spare point type distributor, resister and jumper wire. It saved me more than once.
67 Camaro HEI and electric choke question colincamaro Engine 13 01-17-2007 11:50 AM
Quick question on HEI coils. Jmark Engine 7 11-02-2004 09:11 PM
69 Pontiac Firebird HEI Distributor Question pontiac69 Engine 13 12-01-2003 08:35 PM
GM HEI Distributor question Jag Daddy Engine 8 10-30-2003 05:12 PM
HEI Timing question help gurus please bigmark Engine 21 09-10-2003 05:37 PM
