I always wanted dual quads...........
Here's another of my hare brained ideas. Mild 464 Big Block Buick with a 200-4R in a light car built for mostly cruisin'. I have a 430 Buick and just ran across another 430 and a 455, the same guy has an Offy 2 X 4 intake that mounts Holley carbs. As a youngster I always loved the look of dual quads even though I knew a single would work better and even though I'm an old fart now that hasn't changed. With a lot of tuning and progressive linkage I think a pair of 390 Holley's would be fairly streetable on something this large. Anyone out there ever run a similar setup?
I remember riding in a 402 '69 Camaro with dual 600 Holley's on a low rise intake. A different induction system may have worked better but that one worked plenty good! The 4.56 gears probably helped some This will be a stump puller in a 3200 Lb. car and I'd be doing the quads 110% for visual impact, I know a good Q-Jet on an Edelbrock B4B would work better and get better mileage BUT come on, DUAL QUADS on a Big Block Buick in a Studebaker Coupe! Who couldn't like that?!
Back in the day, a good friend had a 69 Judge, ram air 4, 400 with 3-2's. To save weight, we left the hood off. Pretty cool looking. 5.13's and a 4 speed, it was a real rocket off the line up to about 50! LOL
I'd like them better if you made up a mopar type cross ram manifold....
with the shape of the stude hood that would look great peaking out a bit...aka "Big Daddy" Ed Roth stuff...and they work correct that way |
If I ever get of this computer and get out to the garage i got a tunnel ram project that needs attention. (Like you mostly for the visual impact and grins)
Might even get into a bit of nitrous on it to see if I can split the block in half. I say go for it. Your small cfm holleys or some AFB carbs should be fine. |
GO for it.
Nothing like a pair of quad's, 2 extra barrel's for flow. I run a pair of 650's w/annular booster's on top a cross ram & 434 roller sbc in a 2800# car. I have a different cross ram i'm repairing /flowing /porting to install on it. The 390's have vacuum secondaries which would be good for a heavy car/truck, I don't think you would be happy with them. Mileage depend's on the fast pedal. What is the LSA of the cam ?
Luv the smell of NITRO in the morning. |
I've only run 2x4 once back in 68-9 on a 64 chevelle ss with a 283. It was the stock Vette iron manifold w/small base carbs. Never could get it to transition without a bog. A older friend with some experience tried in vain to get it good.
Multi carb motors need lots of sun to run right.. ... toss the hood
I would get (and did on my motor) the 110 LSA.
With the light car & auto trany @a 650 rpm idle I can put the pedal down. I have no problem with the responce both 4's open all the way. I ran a 10:80 @ 129.80 with a larger lift cam installed. Its only as good as the tuner. Some good articles in the Knowledge Base Engine section on this site. If you ever need help send me a PM.
Thanks. |
I say go for it.... I am putting this monstrosity on my 454 in my 34 coupe. Definitely more for looks, and I'll gladly suffer the long warm-ups and slightly worse gas mileage - okay, who am I kidding, this thing will drink gas like it's only $1.50 a gallon.....
Go for it. dual quad looks great. Change primary jets to #57 on a Holley 390. I replaced the secondary plates with a pair secondary metering block from a 780 Carb. used #62 jet for the secondary. 390 Holley carb run very lean. The exhaust valve will turn white.
| How do you ask for help wanted? | bud34pick | Hotrodders Site Suggestions and Help | 1 | 04-28-2008 07:48 AM |
| Dual inlet/single outlet Flowmaster SUV 50 Series Muffler for AMC 304 | Houman SS '70 | Engine | 2 | 12-18-2007 08:14 AM |
| single and dual groove pulleys | cardaddyo | Engine | 1 | 03-01-2007 10:27 PM |
| Dual Master Cylinder Brake Pedal with Balance Bar | iceman36 | Suspension - Brakes - Steering | 6 | 02-24-2006 12:55 PM |
| Dual gas tanks with EFI | dh79 | General Rodding Tech | 9 | 01-13-2006 07:40 PM |
