Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - I am CORNfused!!!
Old 10-23-2012, 02:49 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
The motor cannot run on if the throttle blades are closed. Early 70's GM cars used a solenoid that closed the blades when it was de-activated (key off). When you turned the key on, 12v activated the solenoid and it moved the throttle plates to the idle position. You can still find the arrangement in boneyards and adapt it to your carb. I haven't fooled with them for many years now, but I'll bet you could still buy a new solenoid over the counter at your local Chevy dealer.
