thanks guys, Ill look into eastwoods kit |
Yes... That is a nice job. I will revise my comment about needing some kind of filler over it. Obviously some people can work it so they don't. I personally don't like to sand lead, and have all of those small particles in the air. I will say that I have not worked around any "lead Masters", in fact not around anyone doing lead work in many years.
I don't think we even knew about hazards back then. Aaron |
Is solder for everybody?-no I've seen it bite people in the arse with trapped acid coming back to haunt them after the car is painted. I had two sail panel seams go bad one time on a 69 Chevelle SS resto because the acid was trapped in the overlapped seams-now if I solder anything the seam gests welded completely closed before I acid the area. When I went to bodyshop school years ago the first thing we learned was metal finishing and solder technique-now I bet they don't teach either. Back then it was picking and filing-which now I know isn't the best approach. |
The only thing I built with lead was an x-ray cabinet for welding inspection. it was 8'x8' with a 2"x2"x1/4" angle frame with 4'x8'x1\2" lead sheets bolted to it. Cut the sheets with a skill saw drilled and counter sunk the bolts. never used a mask but did use gloves and safety glass I should have use a mask I bet I got some lead exposer but only build two of them years a go. like you say you never know what you have been exposed to over the years. Any one remember when MSDS sheet came out. And you found out all the junk you were exposed to Craig |
| Where to get some practice paint | FrankR | Body - Exterior | 3 | 10-23-2005 06:08 PM |
| Paint to practice with? | boyeajd | Body - Exterior | 2 | 03-18-2005 01:04 PM |
| free online practice tree??? | 1967stang | General Rodding Tech | 4 | 11-23-2004 04:45 PM |
| Cost of getting a practice hood sprayed? | norcal | Body - Exterior | 1 | 06-28-2004 04:33 AM |
| netHoleshot practice tree | crshrmn3 | Hotrodders' Lounge | 2 | 01-16-2003 08:49 PM |
