i am having starting issues with my 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2011, 06:32 PM
83chevytruck's Avatar
just put the motor in this weekend, she started right up. the issue is after it has run for a bit it will not start back up. i have put a timing light on it and its about three degrees advanced. the engine is a 79 model with the timing tab straight above the water pump. it has been bored .60 over has a .496 lift mild cam stock heads and top end for now. it seems to run good driving it is a little sluggish on the take off but then its ok. does not idle well at all seems to be all over the place at times. any help is appreciated here....
Old 04-11-2011, 08:22 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Sounds like it may still be out of time and could be the carb adjustment along with a vacuum leak somewhere. JMO
Don't really think you have it dialed in just yet. IMHO
Cole
Old 04-12-2011, 07:07 PM
thanx for the input , found a bad vacuum line this afternoon and also took the starter apart and found it burnt severely inside, the field was shot replaced it, adjusted timing a bit more and its doing alot better. found out that i cannot set the timing by the timing tab, DUH, i should have known better to much cam so its well off the mark i have to guess here but close to 14 degrees or so. still has a gas raddle with a load so i am gonna keep adjusting till i get it right.
Old 04-12-2011, 08:27 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That cam (.495" lift) isn't really that mild in a street driven 350 SBC. I'd expect it to have at least 230º duration @ 0.050".
You'd like there to be at least 16º BTDC at idle speed, more would likely be OK. For the total timing you need about 36º-38º BTDC total, all in by about 2500 RPM. You will need a set of springs to change how soon the advance comes in. Advance weight and spring kits are sold but use just the springs.
You may need to modify the distributor to limit the total advance so as to not exceed the desired 36º-38º total timing. You want about 10º-12º of vacuum advance. Connect the vacuum advance to a manifold vacuum source. This will help keep the idle RPM up, w/o opening the primary throttle blades any more than they need to be. If they're opened too far, the idle will go pig-rich and you'll lose control using the idle mixture screws.
If needed, there are adjustable vacuum cans like the ACCEL #31035.
If you find the vacuum advance adds too much advance (more than 10º- 12º) but is OK otherwise, you will need to physically limit the vac can's travel w/a vacuum advance limiter: [/B] Crane #99619-1; #99619-1 INSTRUCTIONS.
If you're unsure, or just want to check the accuracy of the tab/mark for TDC, DETERMINE TDC will help you to see for yourself.
You can use MAKE A TIMING TAPE for instructions on making a temporary timing tape to use to check/set the timing if you don't have a dial back timing light. Before removing the tape, permanently mark the damper w/the total advance position and any other positions you want.
Need help - starting issues RickyDoors Engine 18 03-26-2011 10:03 AM
406 Starting and High RPM Issues manchildau65 Engine 2 05-16-2010 10:58 AM
hot starting issues on C10 redtide151 Electrical 3 07-21-2009 07:25 AM
92 Camaro Starting Issues 41CHEVYCOUPE Electrical 1 12-13-2008 01:26 PM
283 starting issues 283jeep Engine 18 04-03-2007 11:48 AM
