I am looking to convert a gasoline car into a diesel. Can that be done? and How?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2012, 05:32 PM
I have a 1993 Buick century and I thought it would be cool it make it a veggie car But I don't really work on cars. But I really want to. So I was wondering if someone on here could help me out. Tell me what kind of engine they might use for this project or anyother info I may need to get this project started. PLEASE AND THANK YOU for the Help
Old 04-18-2012, 06:35 PM
cool rockin daddy's Avatar
NO. Look up GM diesels for Oldsmobile and find out why. Bottom end is not strong enough, heads are all wrong. NO.
Old 04-18-2012, 06:51 PM
The cylinders and block is EVERY modern gasoline engine will be FAR TOO WEAK. That's why a Duramax diesel engine weighs 835lbs
Old 04-18-2012, 06:56 PM
LATECH's Avatar
Short answer is no. Long answer is yes, but WHY?
If you want a french fry oil burner get an old mercedes diesel or VW diesel and set it up to go. It will turn out good without a lot of money.
The project you are talking about , converting a gas engine to diesel would be costly and ardouos at best. Then you have to find and injection pump to run it. After all that much work and cash, i wouldnt be dumping in any dirty old french fry oil.
Find a diesel engine and adapt it to your buick, or adapt the car it is in to burn the french fry oil.
Old 04-18-2012, 07:01 PM
LATECH's Avatar
Olds also made a V 6 version of the crappy diesel engine. Pretty rare.
They are pretty much all gone by now, I am certain.
I did see that there are guys using the 350 diesel blocks to build hi performance engines. they can handle lots of horsepower because the castings are heavy/strong.
Who's the dumber one... a diesel in gasoline accident curtis73 Engine 14 07-23-2009 11:52 AM
diesel vs gasoline pollution mitmaks General Rodding Tech 15 12-23-2006 02:53 PM
Diesel turbos on gasoline engine? rockport_juggalo Hotrodding Basics 14 07-24-2006 08:57 PM
Gasoline vs. Diesel nightrain_rod Engine 58 12-13-2005 11:45 AM
Converter, diesel vs gasoline Norwegian Transmission - Rearend 1 10-29-2002 02:24 AM
