I am so confused - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2008, 06:34 PM
WildWillie's Avatar
New Member
I am so confused
Hello all,
I am writing to ask for help in getting the most out of my 355 SBC. It is in a 1971 Nova, with a TH350, 2500 stall converter, and an 8.5" rear with 4.11s.
My current engie car is 90% street, and 10% strip. I would like a lumpy idel, but do not want to lose street manners. Any and all guidance is most appreciated.
WildWilliene:
355
9.5:1
461 heads 2.02 / 1.60
Summit cam 234/244 @ .050 .488/.510 (with 1.6 rollers .520/.544)
Weiand Stealth intake
Edelbrock 750
MSD ignition
The motor is not running right, and falls off around 5300-5400 rpms. I need a combination that will wake up this Nova. Please suggest a top end that will make some decent power. This car is 90% street and 10% strip. I would like a lopey idle, but it is not entirely necessary. Any and all guidance is most appreciated.
WildWillie
Old 08-25-2008, 11:37 AM
WildWillie's Avatar
New Member
Thanks for responding FBird.
possible weak valve springs and or low cylinder head flow and or restrictive exhaust. I had heard at one time that the 461 castings with the 2.02 / 1.60 valves were good running heads, but on this motor they are laying down around 5500 RPMs.
Are the heads stock or ported (more than a pocket port job)? A 3 angle valve job is all that has been done to them, along with hardened seats
Are you willing to change the torque converter to a higher stall speed for a cam swap possible cam+ intake manifold swap? As it is right now I am looking at the Lunati 300/515 bracket master II cam, along with a possible set of aluminum heads from Edelbrock, have a call into Canfield heads as well
If the heads are stock or near stock are you willing to do something about that? Yes I am if the price is not outrageous. Again, I am looking at the Edelbrock Performer RPM heads, as well as the Canfiled 23-500 heads
"Stealth" is that the older Weiand #8016 manifold? or the newer RPM style hi rise clone? My Stealth is the older design, supposed to be good from 1500-6500 RPMs.
I appreciate any and all feedback, I am looking at updating the heads and cam this winter if that is what needs to be done. I am also looking at re-ringing the pistons to restore compression. I have good compression, but if I am tearing it down that far I might as well do piston rings and new bottom end bearings while it is out.
WildWillie
OK, now I'm more confused than before. 58Chev Electrical 4 03-18-2006 03:58 AM
Confused TH350 or TH350C NIWROC Transmission - Rearend 13 12-16-2005 06:57 PM
Confused. Skunk Engine 11 11-05-2004 02:48 PM
Confused And Alarmed... KULTULZ Hotrodders Site Suggestions and Help 3 01-19-2004 02:30 PM
confused??? cranknrods Hotrodders' Lounge 7 08-11-2003 02:48 PM
