i am trying to figure out what my engine came out of help please!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2011, 10:18 AM
ok so i know i have a 3970010 4 bolt main it had 3998991 heads the numbers in front of the left head which i believe is the vin is vo317thb and c63308694 i do not know how to decode this and i was trying to look it up which its not really a big deal cuz i tore it down and about to take it to the machine shop to do a 355 build but it is driving me crazy because i cant figure it out lol if anyone can help i would appreciate it thanks
Old 02-16-2011, 10:34 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If the heads are original to the engine, it's a 350 from a 1977 C30-size truck.
There is a date code on the other side of the rear of the block from where you got the -010 casting number. It will read something like "C 12 7" or something like that.
3970010- '69-'79 302/350 car & Truck 2 & 4-Bolt. This is a common block for having a 4-bolt bottom end and are a good foundation for a performance build.
3998991- 307/350 '68-'79 1.72"/1.50" 76cc chambers. These heads are not what you want to use for a performance build. They have the small valves often seen in the larger truck engines (for torque) and may well have 3/8" exhaust valve stems instead of the more common 11/32" stems. The heads will have a date code similar to the block. You can check to see if the dates fall close to each other to know whether the heads are original to the engine.
THB- '77 350 Truck 165 HP LS-9 Manual 4bbl C 30
THB- '82 350 Truck 160 HP LT-9 Manual 4bbl C-20 & C-30
Old 02-16-2011, 10:49 AM
Thank you it was driving me crazy yea i figured the heads were junk im going with vortec heads think they would sell on cl or should i just toss them in the scrap pile
Old 02-16-2011, 12:57 PM
The VIN V0317THB says the following:
- V equals Flint MI plant
- 03 equals March
- 17 equals the 17th day of the month
- THB is code for a 1980, heavy duty truck (1 ton or larger), LS9 350 rated at 165 horsepower with a 4 barrel carb.
If this block isn't cracked and is bore-able, this should be one great foundation to build from.
Bogie
Old 02-16-2011, 01:50 PM
thanks thats crazy march 17th is my birthday lol it has not been bored and i havent seen any crack but i am gonna be taking it to the machine shop soon
Old 02-16-2011, 06:06 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Before you go off half cocked- check the date code on the block.
Old 02-16-2011, 06:35 PM
These probably won't be the same, The VIN stamping is either the date the block was machined, the engine was assembled, or arrived at a vehicle installation point. The cast in date code is the date the liquid metal was poured into the mold at the foundry. There can be a lot of time between the latter and former events.
Bogie
Old 02-16-2011, 07:14 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Bogie
The difference in the casting date and the VIN/suffix code will not be measured in years, rather in weeks or months.
The info from here (FWIW, I have found this site to have the least amount of errors among the online sources for suffix codes and casting numbers)- http://outintheshop.com/faq/casting/castings2.html
indicates the following:
I also see the 991 heads that are on this engine were used during the same time period ('68-'79) as the first listing shown for the "THB" suffix ('77), not into the '80's.
So if the block and heads' casting dates show this engine to be made in 1977, I would not be the least bit surprised.
BTW, http://www.nastyz28.com/gm-chevy-cod...s-suffix-7.php shows THB to be either '77 or '82. http://www.chevylegends.com/forum/ar...php/t-618.html shows just '82, http://www.chevy-camaro.com/chevy-ca...es.asp?group=6 shows '77 and '82.
These are the first 3 different sites from this google search:http://www.google.com/search?sourcei...vy+suffix+code
I didn't see '80 mentioned in regards to "THB". Any chance your reference material is in error?
Engine trouble- can't figure out a problem. vintagegirl Engine 3 09-08-2009 06:34 AM
Engine skipping can't figure it out Tubbed71 Engine 14 08-16-2009 05:59 PM
need help to figure out 58impalacali Body - Exterior 0 07-08-2008 09:55 PM
Can't figure this one out..... dmaggard Engine 20 11-17-2006 01:24 PM
Can't figure it out? Marcus Transmission - Rearend 0 06-20-2004 08:25 PM
