You should set the caster at about 7 dg. Springs should mount at a 90 dg angle to the centerline of the bones at ride height. There is a ton of info here if you use the search.
Watch that bumpsteer. |
Thanks for the insight. I want to use a split drop axle.
So basically it will be an independant front suspension. I'm still going to use the cross-leaf spring, regular 4" drop tube axle and radius rods. From what I read about this set up, it takes away some of that bump steer. But, does this set up change the caster angle numbers or is it relative to most all other front end set ups? Is there a way of determining the amount of sag of the spring set up to establish ride height? I know that with most coil setups you can get this info from the manufacturer of the coil spring/shock assembly and without physically having the parts you can determine the ride height. I plan on running an all aluminum buick V-8, 215 cu.in. motor. They were made in '63-'65 and came in the Skylarks and Specials. So, it will be lighter than a small iron block Chevy. Last edited by ccrodshop; 01-28-2007 at 10:53 AM. Reason: added questions |
Fatman makes that kit, it requires that you split the tie rod as well to eliminate bumpsteer.
http://www.fatmanfab.com/07page2.htm Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
You might want to reconsider that split axle front. Body roll induces camber loss in cornering and also induces oversteer. In some cases it can be sudden and dramatic ala early Corvair. A book on chassis and suspension will tell you all about it.
I never thought of that. Thanks for the insight.
It's fortunate for us young bucks to have the knowledge base of guys who've "been there" and "done that". This website is an awesome tool. I just hope that there are enough of us young bucks to soak up the knowledge to pass it on to younger generations. |
Even the early ECONOLINE front axle (soild) had a sway bar. |
Look at where the axles pivot compared to the spindle centerline. The roll center is not on the spring end anymore but DOWN at the axle pivot. A bouncing front end makes the camber look crazy..... Suprisingly they drive and ride pretty well, but I have only been in one. and I was impressed. Quarter eliptics or coil overs should be OK. Last edited by xntrik; 01-28-2007 at 07:07 PM. |
I was looking at the Fatman Fabrication split axle kit (the one powerrodsmike was talking of). If they are selling this kit, it must be safe or there would be one helluva liability case there. Not saying it's the best.
Have any of you guys driven/rode in a hotrod with this set up? To me, it looks like the best of both worlds. After this discussion, I might stick with the standard axle/spring set-up to get started. I can always install the IFS setup at a later date, after I get some miles on the car |
Check out this page in cboy's journal on how he used an 81 front suspension in his rod:
http://www.hotrodders.com/forum/jour...ge=5&reverse=1 |
Shannon....just to compare, Flaming River has just recently came out with a new split tube axel set up similar to Fatman except the axle does'nt split in the middle. Punch up www.Flamingriver.com and look under "new products" bottom of page. They call it "Dominator" (???)
![]() I am not sure I like the appearance of swing axles...
I remember seeing that last year sometime and thought it was lame.
I think if I wanted an F150 front end under my street rod, I'd do it like cboy's buddy charlie does. (go look in cboys journal that home brew put up the link to.) Do you see the price of that dominator? 3550.00 I could buy 3 whole trucks for that. Mikey
| 7 and 5/8 rear end drivers side axle leaks | fumplet | Transmission - Rearend | 7 | 03-02-2006 01:39 AM |
| Axle Information. | M&M CUSTOM | Transmission - Rearend | 1 | 02-21-2005 01:37 PM |
| Axle stud installation | 71gtx | Transmission - Rearend | 11 | 12-31-2003 08:05 AM |
| King-pin fit into chromed beam axle? | Limey Simon | Suspension - Brakes - Steering | 2 | 11-06-2002 04:40 PM |
| 34 ford truck front axle ideas and questions | lilred34truck | Suspension - Brakes - Steering | 1 | 10-30-2002 05:20 PM |
