I blew my Auburn posi apart this week end. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2007, 12:03 AM
ElCa/monty's Avatar
so much for it being stronger then a stock posi.
the posi i had in my trans am took 4 years of BB abuse and never once let me down.
my monte has a Auburn posi and it flys apart after 6 passes.
i thought these were supose to be stronger then stock.
i got the car with this posi in it i guess the guy i got it from should have put a spool in it instead of this POS posi.
oh well it will have a spool in it next time i take it out.
can anyone tell me if its a 8.5 or a 7.5 10 bolt.
its the stock housing and the car is a 77 monte carlo.
anyways heres a pic of what i found when i took the cover off.
Old 07-02-2007, 07:03 AM
You've already got it apart just measure your ring gear. If it measures to 7.5 inches thats what it is. and if it measures to 8.5" then its a 8.5
Old 07-02-2007, 09:24 AM
ElCa/monty's Avatar
thanks ill do that.
Old 07-02-2007, 09:08 PM
Yours should have an 8.5", but to be sure, look at the backside and compare it to the two drawings below (stolen from ColoradoK5.com). Look at the projections at the 5:00 & 7:00 positions. The 8.5", on the right, has two big triangular projections. The 7.5", on the left, has two little thin "fangs".
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 09:03 AM
Auburn Posi High Perf vs. Pro Zeder Transmission - Rearend 0 03-04-2004 09:41 AM
Auburn limited slip posi jacobm99 Transmission - Rearend 2 01-25-2004 08:13 AM
Posi Rear end gears 1968rallysportcamaro Transmission - Rearend 1 02-18-2003 02:52 PM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 10:50 PM
