Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - I bought Dupont products to paint rusted car parts, but I feel like I'm wrong...
Old 10-07-2009, 11:26 AM
cyclopsblown34's Avatar
cyclopsblown34 cyclopsblown34 is offline
Colorsanding painter
The sanding scratches the epoxy covers can be no finer than 80 grit. As for 2K primer, ask the supplier for some Nason 2K primer. They offer a 4:1 mix I think and it is a high build polyester or Urethane, I can't remember which. They should be able to supply you a one quart kit and the same quantity on paint and clear. That is unless they already mixed the color as a larger quantity.
As for sanding the epoxy, I usually let it dry a couple days if I'm going to sand it and then only gently so it doesn't gum the paper. i usually don't sand the epoxy, I try to get the 2K primer on it while it is still "open", that way the 2K primer sticks by chemical reaction.
