LinkBack | Thread Tools |
Looks good to me. Make certain your sanding of the filler is within the tolerance of the 2K surfacer/primer. Don't get much finer than 600 grit before the color/base coat goes on. it needs some tooth to bite to.
When you mix the filler make certain it is consistent color and not two colors. mix just enough for the task at hand. You shouldn't need more than a quart of any of the materials you're looking at. You do need lacquer thinner/gun wash for cleaning the paint gun between materials through it. A set of gun cleaning brushes doesn't hurt either. |
Ah...,
You are just making me feel more uncertain all the time But you won't get rid of me like that! I really plan to try to paint it whether it's cheaper to buy new parts or not. The question is more about the fun and the thrill to try it for the first time. This car is my big toy. I don't care about its value. This is my first car and I try to fix everything on it. If I do worse I'll send it to the garage. Now, I'm not gonna keep the etch primer for sure, I bought that because it's in a can and I have only 1 gun. So, wouldn't have to clean it 3 times. I didn't know what I was buying and the guy at the shop gave me this primer. When I saw primer, I felt confident because primer is what you use before painting when you have to paint a room. Well, I realize it is not so simple with car painting. It seems that 2k primer is a bigger need, but what type should I buy? I want to stick with Dupont to ensure the compatibility of chemistry. I'll go take a picture of my car outside to show you the damage. |
Please disregard this post. The post below has answered my question.
dp 90 is not etch primer, it is ppg's epoxy, before it went lead free. Can't remember the colors, 90=black? but ppg used dp and the number after it was different for different colors. Was a very good epoxy. Not its dplf, and I haven't used it since the old dp days, but in past threads it has been discussed how the quality has declined since it was reformulated and went lead free.
I'd personally would use epoxy, and return the etch, and let the bang em out collision shops use the etch. I have to agree with deadbodyman here. To many risks (now or in the future) and potential compatability problems with the acid components for the quality of the product IMO. It also is a 1k product that stays soluable and can be softened by solvents in materials applied over it. The Etch primers I have used were not meant to be applied heavy like dbm meantioned, and they would easily enough run all over the place if applied heavily, and another primer must be used over them before paint (again watch compatability). I haven't used etch often, but when I did, probably used variprime the most. Many manufacturers have strict warnings in there product data sheets about not using bodyfiller over etch or etch over body filler, as the acid etch and polyester fillers don't get along, and the filler could never cure properly. You better make sure it has cured plenty enough time so that the acid component won't cause a problem with you filler or other products. The safest way with least risks of problems and incompatabilitys, that will give a strong foundation for a long lasting durable paint job, IMO is physically removing all rust, sand any baremetal with 80 if not media blasted for something for the epoxy to hang onto, and start with an epoxy foundation over baremetal and under filler areas, apply filler over epoxy and seal up bodywork areas with epoxy. I have no problems with a high build urethane primer (and I've used them often enough) over the epoxy if needed, but urethane primers do shrink somewhat, and are somewhat porous, and will not give the best corrosion protection applied over metal, so epoxy is prefered first under the urethane. But if you have a straight vehicle, and spend a little extra time finishing off your bodywork and getting it straight, epoxy may be all you need for a primer. Most epoxys don't have the amount of build of a urethane or sand as easy. But I used only epoxy on a dent repair this weekend. I used southern polyurethanes epoxy, and it has a bit more build then other epoxys I've used, and could be dry blocked the next day. Choose the best color for coverage of your base color, finish off your bodywork well, and epoxy may be all you need. |
Ok,
Let me resume again everything. Whatever I do, I'll have to make a compromise if I don't want to buy the whole range of Dupont products. Plan A sandwich with epoxy primer -Bare metal -Epoxy-primer -->Sticks well on metal and protects against corrosion, I am in Qu頡nd corrosion is a problem here. -Bondo -Epoxy-primer --> Which needs a 80 grid finish to let the base coat sticks to it -Base coat -Clear coat Pros: Good protection against rush, no need to buy 2k primer Cons: Finish may be rough between epoxy and base coat and the final result may reflect this. Sanding could be long because the epoxy is hard. Plan B sandwich with 2k primer -Bare metal -Bondo -->no real barrier for rust -2k primer filler ---> easy to sand for a smooth finish -Base coat -Clear coat Pros:No need to buy an epoxy primer, easier to sand to get a smooth finish Cons: No real protection for rush in between. Plan C sandwich "gourmet" Stop looking at your wallet and go buy epoxy and 2k primer Which menu would you suggest? |
Wow,
Now ready to go! I'll just switch etch for 2k primer at the NAPA shop. Thanks a lot for the information and tips, it is very interesting and useful. We'll meet on another thread soon I think. I need a paint gun now!
Just to make sure you understand, body filler needs a 36-40 grit scratch to hold on to. So sand rust off with 36 grit, apply filler, sand that with 80 grit to form it, then 220-320 to remove the 80 grit scratches. After its sanded with 220-320, spray your epoxy primer. Once its dry, block sand it out with 400-600 grit. Now your ready for base and clear.
The epoxy won't stick to those fine of scratches finer than 80 grit. As for sanding the epoxy prior to paint, you can sand the epoxy as fine as you wish but I don't get any finer than 600 grit before applying paint.
| what is the fastest (factory) car you have ever driven? | badknuckles | Hotrodders' Lounge | 320 | 12-09-2011 01:32 AM |
| Accidentally bought another beetle.......... | zbhover | Hotrodding Basics | 7 | 04-07-2009 06:17 PM |
| what color to paint? | jum | Body - Exterior | 14 | 07-30-2006 12:29 PM |
