You Can Do It
Yes You Can Use A C Clamp. I Use A Ball Joint Press , Its A Heavy Duty C Clamp . Clamp It Down , Remove The Torsion Bolt And Spacer.
Back Off C Clamp. Mark The Bar At The Controle Arm And Arm , Wiggle Bar To The Rear Until Out Of Arm (tap Out Some Times) Then Pull Forward. (JACK THE BLAZER UP BY THE FRAME.) |
I got everything apart on the blazer, except the torsion bar is stuck in both ends. I assume its supposed to slide out of the socket of the LCA? and the rear key? it wount budge... and tips? the only thing I can think of with the tools I got is a a bottle jack sideways, pushing the TB out. it dont seem to be working either. I got it pumped up pretty tight and drowned in oil. we'll see if i make any progress tomorrow
Why did you drive it home like that instead of fixing it where it was?
Shane |
Did you try pushing it forward to remove the key then to the rear to remove the bar out of the arm. The lower arm might be bent and not releaseing the bar. bigger hammer after key out to go to the rear to remove bar...
I have it all unbolted and whats left of the LCA is held in place only by the stuck TB. I've been striking it with a heavy hammer foreward to no avail. I'm keeping it soaked down with penetrating oil for now and try in tomorrow
| 94 chevy truck runnin' like poo! | bluesmanjesse | Engine | 11 | 11-09-2006 02:54 PM |
| looking for a pic - the Navarro (?) families 68/69 chevy truck | lowROLLERchevy | Hotrodders' Lounge | 0 | 10-03-2006 03:24 AM |
| My new(used) truck | 1931 steve | Hotrodders' Lounge | 5 | 09-02-2006 11:54 AM |
| help identify truck | blackbeard | Suspension - Brakes - Steering | 2 | 01-25-2005 06:28 AM |
| Ebay Truck Headache | CrashFarmer2 | Hotrodders' Lounge | 8 | 09-06-2003 07:30 PM |
