i.a.c. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2007, 12:05 AM
i.a.c.
Is it common for the i.a.c. to wear out on an older 4.3 v6? If it goes how hard is it to replace or refurbish?
Thanks, Clint
Old 10-27-2007, 06:45 AM
It is common for them to get gummed up and need cleaned.It simply unscrews from the side of the throttle body.Has wires plugged into it and is a large size hex I think 1and 1/16. unscrew it and clean with carb cleaner reinstall.
Old 10-27-2007, 06:53 AM
Notorious's Avatar
Hot rodder, not street rodder!
Handle it carefully and don't disturb the pintle. And yes, they do wear out.
Old 10-27-2007, 12:54 PM
If you take the IAC off and clean it don't forget to clean the seat it seals on. Usually a Q tip will do the job if you can't get a fat finger in there.
