I can assure that oil pressure had nothing to do with the head gaskets blowing. I hope that when you checked your block for flatness that you checked not only length wise but also diagonally. I would suspect that your problem is caused by the wrong head gaskets. Felpro 1003 gaskets have a steel wire ring seal sandwiched inside the stainless seal around each cylinder.
The steel ring can tend to brinell the aluminum heads. Felpro suggests using their 1010 gasket that uses a preflattened copper wire ring. I would pull both heads and check the block for damage even if it was good when you put it together. If a motor runs too long with a blown gasket it will damage the block. You will need to get the heads surfaced if the steel ring has started to indent the heads. Install the Felpro 1010 gaskets with no sealer. You will need to put sealer on the threads of the bolts to ensure water doesn't get past the threads. Even if they are no re torque gaskets I re torque head gaskets on any performance motor. |
Are you leaking coolant or compression? Use no sealer on the head gaskets, but do use a non-hardening sealer on the head bolts. Re-torquing the bolts is always a good idea with a composition head gasket. Have the heads resurfaced, a straightedge doesn't tell the whole story. Most aftermarket heads are in need of straightening right out of the box.
Thx for the tips. Tom, I have not checked compression and I am leaking oil from the head gaskets, not coolant.
When I re-did the head gasket before, the gasket showed no signs of failure. On first rebuilt @4000 miles ago, I did have the block machined so I know it was flat and true. I guess I will order the 1010 gaskets and hope for the best. |
leak
Is it leaking oil from both heads or only one??
Is the leak in the front or rear of the engine?? Is the leak the same place as last time??? Keith |
Ahh, It's an oil leak you are concerned with.
That's good news. I don't think you can leak oil from the head gasket! There is no oil passage there. At least there better not be. Sounds like a leaky valve cover gasket with oil running down on the head. If your coolant is OK, you are not spiking a temp, & no coolant in your oil. I would bet you have a very easy fix on your hands. I certainly wouldn't rip off the heads for an oil leak! |
leak
Wings, the oil return holes go through the heads in a small block so there is a chance oil can leak through the head gasket. Even though is a very small chance.......
keith |
Keith, The oil returns (pushrod holes) drain down under the intake and do not pass through the head gaskets. That is why I'm willing to go out on a limb and say that any oil leak you see has nothing to do with a leaky head gasket.
Re: leak
Thx very much. Quote:
For the intake manifold, I used fel-pro gaskets and prematex RTV sealant on the ends. Man, I hope you guys are right, I would much rather re-do intake or valve covers than the heads again. Thanks. |
LEAK
Wings,
on the small block chevy the main oil drain back is the 2 holes at the front and rear of the head. These holes are about .470" in diameter. They do dump into the lifter galley. If you look at a head gasket these holes are the ones at the top of the gasket where the triangle part starts. I hardly doubt this is where the leak is coming from, but it is possible to leak oil from this location...... hlweyl, two things i would check if your sure it's not coming from the intake. Look real close at the top of the block where you have the oil pressure gauge hooked up. I have seen leaks at this location drive you crazy. The oil will follow the seam where the heads bolt to the block and it will look like the head gasket is leaking. If thats not it and you take the heads off again check the holes where the locating dowels go into the head and make sure they are reamed deep enough that the head is not bottoming out on the dowels. Keith |
Re: LEAK
If the heads are bottoming out on the locating dowels, would they leak from the get-go rather than surfacing 3000 miles later? |
Re: Re: LEAK
If the heads are bottoming out on the locating dowels, would they leak from the get-go rather than surfacing 3000 miles later? [/B][/QUOTE]
Yes i would think the oil leak would be instant but i have seen crazy stuff happen with engines. I was just thinking of things that might cause such a rare problem....... If you find out for sure that it's not coming from above and running down the head you need to be real careful when you take it apart again to look at the head gasket carefully to determin exactly where it's leaking. Again i hardly doubt its coming from the head gasket!!!! I find it hard to believe that both head gaskets would be leaking oil...... Keith |
