-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   I Can't Find Garnish moldings. (http://www.hotrodders.com/forum/i-cant-find-garnish-moldings-93342.html)
camaro70 07-08-2006 08:38 PM
I need help.I am looking for what i believe it to be called...garnish moldings for a 1967 Nova (post car).These pieces are above the quarter window and hold up the headliner and the sail pannels.Nobody seems to have these pieces.I can't even find a junk yard with an old Nova in it so i could get these pieces.Have tried many places like Chevy 2 Only and Trim Parts..ECT...Can anyone help me with this?Thanks
sjw6 07-08-2006 09:48 PM
Opgi
You might try Original Parts Group. I believe their website is OPGI.com, also the Paddock. paddockparts.com.
Deuce 07-09-2006 07:44 AM
You should try to buy a set for a 1932 Ford 3W coupe ... :smash:
$2500 for a set ...
Good Luck finding the ones for the NOVA ...
I always liked the early Nova post cars ... :)
OneMoreTime 07-09-2006 10:42 AM
www.car-part.com is a good place to search..if yu get to this page http://car-part.com/cgi-bin/search.cgi you can enter the information of what you are looking for and maybe someone will have it..This is the national wrecking yard search engine and someone may have what you need..
Sam
NudeAutoMall 07-25-2006 09:43 AM
Forgive me if I'm not understanding what you are looking for. Are you talking about the pieces of tin that screw above the window for the plastic beeding to hold on to? If so, simple enough to make. I'd knock those out for like 20 a side if you can borow a set to coppy, or 40 from cardboard patterns.
camaro70 07-26-2006 04:37 AM
Yes you are correct.I do not have the part at all.I don't even know anyone that has a set for me to copy from.
NudeAutoMall 07-27-2006 07:36 AM
It would have been easer with a coppy. What I need then is a cardboard cut out, preferably from a laundry detergent box. Screw a side pannel from the box to the place where your pice needs to be screwed to, making sure there is a screw for every hole, and cutting away the excess cardboard as necessary, then trace the opening of the window. Next take another scrap of cardboard and cut a slice in it on one end, only as deep as your plastic beading. now slide that cut over one lip of the beading, cutting away the necessary amount of cardboard so that the cardboard no longer bends as you push it over but still tuches the inside and outside of the lip while just tuching the bottom. What your making me is a debth and thickness guage, and it suld look something like a tuning fork when you are done. The next piece I would need is a simular guage, but of the window channel. Place it 90 degrees to the window channel and cut away untill it fits snuggly at all points, this cardboard will look somthing like your poarch steps viewed from the side with three steps; step one being the post of the car, step two the window channel, step three aproximatly the window pane. And I will need one more cardboard of the inside radius of the rubber that holds your window, or window hardware in.
