I can't be the first person to deal with this - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2006, 02:39 PM
I have a 9" Ford from a truck I was going to use in my hotrod. As I was about to mount the transverse model A spring, I realize the center is not centered on a truck rear end. To get it centered, I'd need to shorten one side of the housing and axle 1 3/8". If the rear were out of sight, I probably wouldn't care, but its going to be seen. I have both axles out and confirmed they are equal length.
I know I'll at least have to shorten the housing, but does anyone know if there is an axle from another Ford car or truck that I could swap without having to shorten or respline? All the measurements I keep finding only tell the full width of the housing and not the individual axles. Mine are 31 spline. A truck would be great so I wouldn't have to drill an axle for the wheel pattern.
Old 11-21-2006, 03:44 PM
powerrodsmike's Avatar
Wiki Edits: 161
Most of the shorter axles would be in cars, and are usually 28 spline.
Typically the axles in cars are of unequal length and one could be the length you need, but finding a 31 spline will be a chore. Those were only put in high performance cars and even then most were an option.
Why don't you save yourself a big hassle and send your axle shaft to Dutchman or Moser and let them narrow them.
You are fortunate in that the 31 spline axles can be resplined alot easier than the 28s.
I think it was less than 80.00 per axle to respline at Dutchman.
i know that our local rear end shop will respline also. You might want to check your phone book.
Who is going to narrow your rear end? They might be able to narrow the axles also.
I just did my first narrowing and straightening on a 9" ford rear. (I need to finish that thread.. )
It was a learning experience.
later, mikey
BE different....ACT normal.
Old 11-21-2006, 05:00 PM
I got a quote locally for $185 to do everything but I have found places that will shorten the housing from $50 - $100. By the time I ship an axle to Moser or Currie, I'm already about $100. I realize it s a long shot to find a suitable axle without needing some modification but it doesn't hurt to ask. Money is just so tight right now and I was hoping to know what to look for in wrecking yards this week.
Old 11-21-2006, 05:53 PM
Wiki Edits: 161
Your limitations are your current 31 spline axles and the pickup truck axle flange bolt circle size, which is unique to the PU and van. Ford full size cars ,of which most were not much narrower, were 5 on 5 while the trucks were 5 on 5.5....The early bronco would be a good pick, because it is as narrow as you will find and has the pickup bolt circle, BUT most of those were 28 spline
Hot rods are fun, huh...
You might be better off looking for a whole rear end that will fit your car when you go to the junk yard.
What are you building?
Mikey
Mikey
Old 11-21-2006, 07:31 PM
Its a 28 Ford roadster pickup as best I can describe. This is my first build. Fenderless, sitting low is the plan. I bought most of this about 15 years ago before the rat rod craze. Just now doing something with it all before my baby girl grows up. Then I KNOW I won't have any money for a hot rod. It will be rough looking at first until I decide what I want to do with the paint. Just trying to make it a roller right now. The frame is home built 2x3 box tubing. The rear end was a freebie a long time ago, so I guess I can't complain. At this point I could either modify the rear I have or start fresh. I think either way will cost about the same not to mention I have little time to chase one down in a wrecking yard.
I set a goal for myself and just trying everything possible to make it and where to spend the little cash I have gathered.
Old 11-25-2006, 01:35 AM
NO Ford 8 or 9 inch rearend fromn car or truck has a centered center section. This is due to the design of the differential unit.
"Back when" nobody cared if the center section was centered, they just cared whether it got them down the road safely and often quickly and had decent brakes to get stopped in a hurry. Cosmetics is a show car idea that drifted over into street rods and hot rods in the 70s and now we're stuck with it...or at least you are. LOL
Old 11-25-2006, 11:57 AM
LordMaximo's Avatar
Last journal entry: Painting
lol......can't help from snickering on this one, if you are going to build this as a daily, who cares! If you look at most drivers on the road, non of the third members are actually centered under the frame. Your most worries is the thrust alignment for your tracking down the road.
Use your local axle shop and give them the credit for your problems. Keep the money in your town and help out the locals. Give them your final measurements and let them have at it. They will pull it apart and make it all even for you. Have fun and good luck.
Old 11-27-2006, 02:51 PM
I decided after pricing what it would take to shorten the one side, it would blow my budget and really not gain me anything. I wouldn't care so much if the rear was well hidden, but we're talking a roadster pickup with a transverse spring that makes it very noticeable. I decided I can live with it and even have a plan to make a trick cover and give the illusion that its centered. I'll post up pics when I get it done.
Old 12-08-2006, 06:58 PM
GMCTRUCKS's Avatar
Ford rearend
My 57 F-100 had a 9" on it but I replaced it with a 1974 Grand Torino rearend the stock one was geared to low I also had the front spindles sized to the same bolt pattern as the rear so that I would just need one spare tire installed a FMX trans and 302 engine it came out good. Good luck!
Deal,, or No Deal ZipZ28 Hotrodders' Lounge 11 01-25-2007 06:54 AM
Which is the better deal...? Bumpstick Engine 3 11-19-2005 11:00 AM
68 chevelle good deal, not good deal? MMkokinda65gto General Rodding Tech 3 02-27-2005 07:48 AM
I just asked about the package deal! HemmiGremmie Hotrodders' Lounge 3 10-16-2003 05:06 AM
What's the best deal you ever got? Busted Knuckles Hotrodders' Lounge 45 03-23-2003 04:45 AM
