I cant get rear drum off my race car Race tommorow - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2012, 01:58 PM
I broke a stud on my back halved Monza It has a 12 bolt with C clip eliminators & som large finned drums. There is no slot front or rear for the star adjuster. I have been heating & beating & nothing, I cant remove the axel because the c clip eliminator is behind the drum.
I have heated & used Ice in the axel stub, that allowed it to move a millemeter I am at a loss any advice will be appreciated
Old 06-29-2012, 02:27 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Some drums are not punched at the factory for the brake adjusters but there are kidney been indentations on the drums that will punch out with a hammer and punch look hard and you may see them ! If your drums dont have these you can drill a hole in the face of the drum large enough to get an adjuster in or a screw driver ( in line with the star wheel) look at an old drum if your not sure of the placement or if you have room you can drill the backing plate in some instances!
Chris
The Following User Says Thank You to painted jester For This Useful Post:
pdmracing (07-02-2012)
Old 06-29-2012, 03:08 PM
There is no kidney bean but I pulled my wheel off my 68 camaro & I see the drum on that car has the hole in the fron, so Drill I will
Thank you I will let you know what I find.
Old 06-29-2012, 06:20 PM
Your welcome Chris
Old 06-29-2012, 06:26 PM
Aren't the holes for adjusting the shoes in the backing plate?
Old 06-29-2012, 06:36 PM
Some are some aren't !
Chris
Old 06-30-2012, 05:32 AM
Irelands child's Avatar
I have actually drilled the outer face of the drum between the studs then tapped the hole with a bottoming tap and jack screwed them off. You wont strength wise hurt the drum or the axle flange.
Irelands child
Old 06-30-2012, 05:44 AM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Cut the holddown pins off at the back of the backing plate, then the drum will pull forward enough to get to the adjuster to back it down.You'll be ale to pull the drum off far enough to get to the adjuster between the backing pate and drum flange
Fact is stranger than Fiction
Old 06-30-2012, 06:31 AM
It worked
I drilld a slot in the drum, got to the star wheel, loosend it to the max and nothing, it is a finned aluminum drun, truck drum? Buick? I have part number on inside I will post later
So I drilled another hole oposide , put my puller in it & it popped off the axel, seems that its a press fit on the axel end when I put it back on I had to press it on teh axel. loading the trailer now thanks again.
Old 06-30-2012, 12:15 PM
Good luck ! Post your E.T. And speeds
Old 06-30-2012, 12:24 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Chris
X2 some front some rear.
Cole
Old 07-01-2012, 11:55 AM
Made the finals!!!
wow what a day at Atlanta Dragway. I finished the brake deal late friday. Got up at 6 Finished the corner balance( or scaling) & was loaded up by 9am.
It was the Big Nite of Fire Fireworks race in the Summit series, so it usually brings out a lot of non regulars so there are points to be won.
The weather was crazy. Atlanta is 1150 feet ASL and normal density altitude for this time of year is 3000 feet. Saturday my first run was 104 degrees ambient, 136 track temp and 4727 DA with 5005 ft OA! car ran off .25 slower than last week but it did it both time runs so I went with it.
Run # 1 113.7 degrees ambiant! 5474 feet DA. 147 track temp It was crazy.
End result I was looking for a one and done just to get some points and made it to the final. Got my first .000 reaction time in competition earning me the bye run in the quarter finals. Semis had a great .003 and in the finals got off with a .002 to a .043 but blew the tires off it, by this time the weather was in the high 90's but the jet cars blew a lot of the rubber of the track and I knew 20 feet out of the gate that it was over. Probably picked up 5 positions in points & I was came in at 8th. Any way you look at it getting home at 1:30 am is a good thing.
Thank you all so much for the advice and giving me the ideas to press on regardless. Im so glad I did.
Oh, to top it off, my fuel pump died taking it off the trailer this morning.
Old 07-01-2012, 04:44 PM
Chris
Drawing: Great Race "Essex Race car" lincoln highway jony Hot Rod Art 3 11-30-2011 01:27 PM
race car question randy_in_texas Engine 19 07-21-2008 07:47 PM
Help my friend race the Dakar off road race propaniac Off-Topic 11 07-29-2007 08:50 AM
race car fordboy_460 Hotrodding Basics 8 03-29-2007 02:30 PM
street race cars (drag race) chris oswalt Engine 18 09-18-2004 10:52 AM
