We're winning the case!
Hotrodders Bulletin Board > Tech Help > Interior
  #16
Old 08-25-2009, 07:52 AM
Riot Racing's Avatar
Riot Racing Riot Racing is offline
I went into a Kragen autoparts thinking there was no way they had the right tool, but Ill give them a shot.
I purchased a door handle removal tool and IT WORKED.
My god, that tool made my life so much easier. I had six handles off within 20mins. No frustration, no swearing, I was stupid to even attempt this without the tool.
Thanks everyone for your help.
If there a tool to put those clips back on?
Old 08-25-2009, 07:56 AM
cobalt327's Avatar
WFO
cobalt327's barnstar
Wiki editor
Last wiki edit: Chevrolet restoration packets
Wiki Edits: 20
If it's the right tool, you use the same tool to reinstall the clips as to remove them.
Old 08-25-2009, 09:10 AM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
DanTwoLakes's barnstar
Wiki editor
This is the easy part. You don't need a tool to re-install the clips. You push them into the groove in the end of the handles with your fingers until you can see the two lobes of the clip in the opening for the post. Once the clip is back in place in the handle, you can push the handle back on its post. If you replace the old clips with new clips, they are a little harder to put back in place, but the heaviest tool you will need is your thumbnail. When you push the handle back on, the clip springs apart and once it is down far enough on the post, the clip engages the groove and holds the handle in place. Make sure you have the handles in the right position before you fully seat the clips, or you'll be doing it all over again. This is what the clip looks like re-installed in the handle.
Size:  137.4 KB  Click image for larger version
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "I can't get the window cranks off: 54 Chevy"
the history of chevy v8's savman1 Engine 30 01-25-2008 01:02 PM
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
'54 Chevy grille effienut Hotrodding Basics 4 03-22-2006 09:09 AM
54' chevy 4 door window channel gavinpierce Interior 1 02-17-2006 03:48 PM
54? Chevy sedan ChevelleSS_LS6 Hotrodding Basics 27 06-12-2005 02:11 PM
