I could use a diagnosis - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-26-2010, 08:57 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
I don't think we have "Harbor Freight" brand tools here in Canada, but I would imagine that they'd be on par with the "Power Fist" brand (Who comes up with names like that? LOL) that Princess Auto sells.
I buy air tools that I know I'm only going to use once in a blue moon from them. Recently it was an air shear and a panel crimper, and I paid about $45.00 each for them.
Oh, and a *really* cheesey 18" sheet-metal brake for about $20.00. At that price, I couldn't even buy the materials to build one myself.
  #17 (permalink)
Old 07-05-2010, 09:14 AM
ended up sanding the paint down to the metal, reshooting the hood and roof, and shooting another 6 coats on the car. clear coated in over 3 days, shooting 6 total layers of clear coat. Looks fine now - has a two tone gunmetal quality to it - kinda cool looking and unique. going to use the rest of the lacquer stuff for my custom guitars. Thanks for all the help!
  #18 (permalink)
Old 07-06-2010, 03:49 AM
deadbodyman's Avatar
Wiki Edits: 11
wait a week or two ....
  #19 (permalink)
Old 07-06-2010, 10:40 AM
ugghhhhhhhhhhhhhhhhh.
  #20 (permalink)
Old 07-06-2010, 10:47 AM
A word about HF: One of the things about them is knowing what to buy. Some of their stuff is junk, but some is perfect for an amatuer that is only going use the tool one time, or on such a limited basis that there is no point to buying a name brand equivalent. For example, the air flanger/puncher I have works perfectly fine for my one (and only one) resto project. Would it hold up in a production shop, seeing use constantly? Probably not.
The hydraulics (jacks, motorcycle jacks) seem to be good. I've been using the motorcycle one pretty heavily as it makes a nice axle dolly too. Of course, I'd be sure to put down some nice jack stands before crawling under.
Their electronic/diagnostic stuff is garbage. At least I've never had any luck there. Although the cheapo digital caliper works well enough for spec-ing brake rotors and whatnot.
Beware the anvils they sell. These are just hunks of cast iron. A true anvil is a thick plate of steel forged atop a cast iron base (true of even authentic anvils from years ago). The first time you miss with a big hammer on that HF anvil, you can expect chunks of iron to come flying off. They actually go the extra mile to cast in a "parting line" between the face and base, but it is pure iron. Shameful.
The 5$ stud extractor I bought from there worked like a 5$ stud extractor- an almost complete waste of time. I guess they forgot that you need *hardened steel to "bite" into a grade 8 bolt.
  #21 (permalink)
Old 07-07-2010, 05:39 AM
Wiki Edits: 11
All my HF air tools have worked very well at my shop...the 3/8 drill (9.99 what a joke) took a crap in the middle of a job but the planetary gears out of a 1/4" air ratchet (from my junk pile) fixed the problem "quick "its been working fine every day since....the metal gears are not hardened very well.so keep them oiled...BTW,I was screwing around fixing a pile of air ratchet's yesterday when I discovered all the the parts are interchangeable from HF to snap on.....every single one....The outer cases are different thats all....The 1/2" impact wrenches dont last long but for home use they're ok just check your lugs with a lug wrench first...
The auto darkening welding helmet has worked great also,for the last three of four years ....Sorry ,this is getting a little of topic...I'll guess start a HF thread
  #22 (permalink)
Old 07-07-2010, 06:41 AM
BarryK's Avatar
Cheap S++t VS good S++T??
OK, I'm 56 bought my first DA, air-file, 3/8 air ratchet, etc in 1970-72 area.
Bought the good stuff, replaced my first DA, somewhere around 1990's with a Dynabrade. Air ratchet about 10 years ago as I broke the original using as a breaker bar, duh.
You guys do the math but no, I do not have a pile of air ratchets to take parts from and the first 9 years, I used these tools full time.
I guess I was raised wrong but then again not real big on wasting money.
  #23 (permalink)
Old 07-07-2010, 07:39 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
With air tools, I've found the same brands from "cheap" to "good" w/no apparent difference at all.
As an example, this is from another THREAD:
The Ingersoll Rand #231 and the Chicago Pneumatic #731-2 (in the MAC cover) are the same tool.
  #24 (permalink)
Old 07-09-2010, 05:34 AM
Wiki Edits: 11
Back when we were starting out (the 7os) good tools WERE good tools ...Now its a different story. they simply stamp their name on something made in another country...One of the most popular tools in a body mans box is the 1/4" air ratchet ,my first snap on lasted years but the last two I bought didn't make it a year.I believe they were about 150.00 ea.One thing I discovered was my high torque 3/8" IR ratchet that snapped off the head still works and has their name proudly stamped on every part inside ,most of the broken tools I have saved are good name brand ons like snap on, Mac and IR.
I save them because I also don't like to waste money But when I found HF had a 1/4" air ratchet for 9.99 I got one for the shop box (everyones use) .it lasted longer than both my snap ons.and all the parts inside are interchangeable.(they are the same one the inside)..At that price I can buy 15 hf air ratchets and never have to buy another so by my math I'm way ahead..buy a 10.00 tool for 10.00 or buy a 10.00 tool for 150.00 I only take bolts out with it anyways its not a precision instrument like a paint gun. I guess what I'm saying is there's no substitute for good quality tools .if you can get them, my Hutchins sander probably the only brand I can still swear by as far as quality.Everything else seems to be made somewhere else with cheap labor and shipped here with a good American name on it...Snap on used to be good and guaranteed their air tools but for the last 25yrs they don't ...Why??? Now you know...
If you went to china and had them make your epoxy primer or clear at 2/3 the price and slapped your label on it and it was exactly the same why would we buy yours at the higher price if it was the same...Or why would we buy ppg or dupont if yours was cheaper and better??? We wouldn't ,thats why we talk about how good you primer is....Because of the cheaper price a lot of guys wouldn't buy it if we didn't talk so well about it ....(cheaper is'nt necessarily inferior) this is no different...Don't let these big companies pee on your leg and tell you its raining.....some of HFs air tools are pretty good the ones I tried and liked are the 1/4" air ratchet,all the die grinders and cut of wheels,3/8 air drill,punch/flanger, Then there's the auto darking welding helmet ,and the Engligh Wheel and bead roller sure have come in handy too...
There's quite a few HF tools I'd avoid but these are the ones I use all the time and still work well...
Basic Video Diagnosis 88 Toyota Tercel Nsomnia Engine 3 04-08-2009 06:12 PM
TH 350 throttle valve diagnosis help Choir Boy Jon Transmission - Rearend 5 07-03-2008 10:15 AM
Daily driver diagnosis -- slow coolant loss pmeisel Engine 3 02-25-2008 04:36 AM
700R4 quick diagnosis? Chuck78 Transmission - Rearend 14 12-18-2006 11:43 PM
Trany Diagnosis pzatchok Transmission - Rearend 2 04-25-2004 12:29 PM
