I could use a real engineers help... - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2003, 08:35 AM
S10 Super Sleepers
Hey, I'm having a hell of a problem with density. I'm trying to enter the density of Beryllium into my CAD package. The problem is that my density givein to me is in Lb/in^3 and the format I need it in is gram/mm^3. I've been looking all day and cant find a calculator or formula to get me what I need. You'all have any ideas??? So far the closest I've gotten is that I set my cad to inches, which gave me my Lb/in^3 for which I entered the number I had. Then I told the cad that I changed the units back to MM and it then changed my density to gram/mm^3, but the number it had in it before is different than the number It changed it to. So I'm not sure if it automaticly converted the density to gram/mm^3, or what. I need to figure this out so I can check the numbers the computer put in. Thanks Again...........
Old 08-05-2003, 08:51 AM
New Member
Hi Scott,
you can do a yahoo search for density conversion and get plenty of sites. One I looked at is onlineengineer.ca/density.htm
It gives kg/mm^3, but just divide this number by 1000 to get grams!
Hope this helps,
Seth
Old 08-05-2003, 09:00 AM
S10 Super Sleepers
It only gave m^3, but I didn't think of converting the weight volume, as long as the measuring volume is the same. I needed to divide by 2000, but it did come up with the same numbers my cad did. Thanks alot. sometimes all it takes is a view from the outside..........
Old 08-06-2003, 06:12 AM
Madd Syntst's Avatar
Returning American Maddman
All those who understand anything in the above boxes please take one step backwards and stand next to me!
Dude, that was some secret sheet!
