Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - i could use some quadrajet rebuild tips
Old 12-08-2009, 03:50 PM
jak327 jak327 is offline
for the bushings do i have to get the kit ($160) or can i use a normal drill bit and drill press to drill out the old bushings and put in the new if i make sure everything is lined up good?
as for the year im just going with what the year of vehicle its in. the carb is probably around 74 or 75 like you say.
