I.D Holley Carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2011, 07:12 PM
The mobile view is crap
I.D Holley Carb
I removed the carb from my 2001 Glastron GX205 today and am looking for a rebuild kit for it. I must not be finding the right numbers because I am not finding anything for a kit. Here are the numbers I am finding.
These numbers are on the same piece the choke plate attaches to 3858334, 75004-1, 1851
This number is on the base of the carb 12r-39750
This number is on the choke casing 34r-6551 r
this number is on the piece that is sandwiched between the float bowl and the carb body 5925
this number is on the accelerator pump housing 34r 27738
go ahead and bash me because I am thinking the same thing you are, how is this ******* going to rebuild a carb when he can't even find the number for the kit
Old 02-19-2011, 07:40 PM
Look on the air horn and find the number that follows the word LIST.Then post the number and I can tell you what kit # to get.
Old 02-19-2011, 08:24 PM
This is supposed to be a marine carb also, can't tell you that for sure or not though, I bought the boat uses
Old 02-19-2011, 09:52 PM
LIST 1851 is a model 4160-----600cfm---renew kit # 37-119
Old 02-20-2011, 10:23 AM
it is only a 2 barrel carb
Old 02-20-2011, 11:01 AM
OOPS .
Old 07-16-2011, 02:00 PM
I'm sure you've already found a kit by now but FYI...use Holley # 702-36 kit for your 3858334 2BBL 2300 carb. The kit includes an alcohol tolerant accelerator pump. I use the green Holley alcohol pump in all of my car rebuilds to combat the problem with e-10 gasoline. It is even more important in a boat for fire prevention!
holley carb backfires threw carb talleyho Engine 63 01-04-2016 10:43 AM
Holley carb ID 2170hatch Engine 8 11-29-2010 03:32 PM
holley carb rosgood14 Engine 1 08-24-2010 12:10 PM
750 holley carb 67impalla Engine 4 04-19-2010 05:19 PM
Holley Carb on 350 Gladis Engine 1 12-25-2006 12:30 AM
