I.D. my straight axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2008, 07:21 PM
I am trying to do an upgrade on my 64 Dodge Polara front breaks, I am looking for any info anyone can give me on identifying this straight axle. Attached are some pics, it might be either an Dodge van of ford econoline van
Name:	100_0653 small.jpg
ID:	27915   Click image for larger version
Name:	100_1859 small new.jpg
ID:	27916   Click image for larger version
Name:	100_1860 small new.jpg
ID:	27917   Click image for larger version
Name:	100_1869 small new.jpg
ID:	27918   Click image for larger version
Name:	100_1865 small new.jpg
Old 02-11-2008, 07:33 PM
I'm not sure what it is, but what it is not is early Econoline.
Bob
Old 02-11-2008, 07:35 PM
No: It's NOT an Econoline and it doesn't look like a Dodge van.???
Old 02-11-2008, 07:55 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
You said you need brake info; I know that "good" parts guys can look up shoes & stuff IF they have the actual catalogs. Do you still have a real auto parts store there??
.........boy I miss the good old days.. We had guys who could tell, & sell you, whatever you needed
Edit: Meaning they can look up brakes without knowing what axle type!
Old 02-12-2008, 06:50 AM
onebadmerc's Avatar
I need a bucket of arc sparks
The tie rod end looks like a Ford set up with the tapered stud.
Old 02-12-2008, 08:50 AM
sharpe427's Avatar
Are there any numbers or symbols cast into it????
Old 02-12-2008, 05:26 PM
Sorry, I did not give enough info
I am wanting to convert to disc brakes, I agree the old drum style looks more authentic but this car is so fast I have a hard time stopping it, I almost bought the farm last fall because they faded so bad, I always wanted to drive a ten second car and I think I am getting close, and that is drive one with out wreaking it. Any info is great, you guys seem to be helping so far, I hope some one can recognize this and help.
Thanks for the replies so far.
Old 02-12-2008, 06:19 PM
Let me look through some pics,I think its like the axle in my old TownWagon.
Shane
Didn't find the pics,I need to organize the approximately 4 gigs of pics
Old 02-12-2008, 06:36 PM
I suggest contacting Scarebird brake conversions. They make a lot of disc brake stuff. If you have the bearing OD size and a few other dimensions ... they should be able to fix you up
http://www.scarebird.com/
Old 02-12-2008, 09:46 PM
Thanks, I am looking at all angles on this, please keep it coming, unfortunately the car is in storage so I cant do allot of measuring right this second, but that has been discussed before and I know I need to do that, I might have to go to the storage and pull a break, thanks for the idea I will check those guys out.
I did not know the townwagon had a straight axle, cool hope you can find some pics, Thanks
Old 02-12-2008, 09:54 PM
I have the pics somewhere in mypictures, The old townwagons and townpanels had solid axles. No many people have even heard of them, Mine has lots of body rust(seting since the 70s) but it was my grandpas and I plan to fixit up one day.
Shane
Old 02-12-2008, 10:12 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Sure looks like a D-100 pickup to me..If it is B-body rotors and hubs will fit as dodge did not change too much of that sort of thing over the years..i would try and find a backing plate from a D-100 and compare to what you now have..Perhaps you can find the hub and rotor from a B-body of that vintage and check that against the hub you have for bearing sizes and such..
Car-part.com may be able to help you on finding the parts..Checked out the scarebird site and that looks like a good one and they are not all that far from me..
Sam
Old 02-12-2008, 10:25 PM
kleen56's Avatar
I may not be too much help here but I'm going by picture #1. I have a 56 Ford truck with the straight axle front end. It's definitely not a Ford truck straightaxle. That axle is straight and has little to no radius where the king pins connect? The shackle ends are much larger also indicating maybe a van or truck of some sort. I also notice the engine is orange and most definitely is not a Ford oil pan. Maybe GM van or truck? You got my interest now...
Old 02-12-2008, 10:51 PM
Actually the car is a 1964 Dodge Polara with a 440 in it, somewhere along the line someone put a straight axle in it and raced it in the Detroit area, I am wanting to do a disc break conversion on the front where the straight axle is but can not identify the straight axle.
Old 02-13-2008, 08:44 AM
kleen56's Avatar
I would try contacting ECI brakes. They make all the disc brake conversions for straight axles and rear ends. I'm sure they can direct you in the right direction. May want to check with Classic Performance Parts also. They have the conversion kits as well.
http://www.ecihotrodbrakes.com/
What do you think of a 63 straight axle Falcon? 63' Falcon Gasser Suspension - Brakes - Steering 23 12-19-2013 10:16 PM
straight axle jstaley4 Suspension - Brakes - Steering 1 03-19-2007 07:44 PM
Straight Axle and Rack & Pinion Murff Suspension - Brakes - Steering 12 06-15-2004 03:21 AM
Straight Axle for 63 Chevy2 musky2 Suspension - Brakes - Steering 15 01-04-2004 01:15 AM
