I did it. Eliminated the 2000 rpm exhaust drone - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2009, 11:14 PM
Ripped's Avatar
Last journal entry: First RoadCourse Video
After changing the mufflers, changing to highway gears, adding another $300 of sound-proofing to the car, I still had too much exhaust noise inside the car.
There was no way of even dreaming about taking the beast on a long cruise down a winding highway without ear plugs!
Last weekend, I was running up a moderate highway hill and gave it a little gas. It was like being inside a drum!
I googled exhaust drone, and came up on a couple forum links (other sites) discussing exhaust drone at 2000 rpm.
Hey that's what I had.
Something about sound waves. The frequency of the engine exhaust and the length of the tail pipes, at 2000 rpm (or therabouts) causing a reverberation... yada yada.
The solution; teeing off a dead end tube on each tail pipe, which is about 50% the length of the tailpipe.
Hmmm- hocus pocus, or will it work.
I also looked at a couple links of BMW exhausts with a resonating chamber built in to the exhaust (attached below)
Okay that sold me. I was going to try it. If it did not work, what did I have to lose? Bonus, there is no exhaust restiction, no power penalty.
ID:	36771   Click image for larger version
Old 03-07-2009, 11:19 PM
4 Jaw Chuck's Avatar
They call them resonators for a reason, try a set on each pipe...beats $300 worth of sound deadening anyday. The longer the better.
Old 03-07-2009, 11:25 PM
Ripped's Avatar
So here goes.
I tee'd both tail pipes. I had an extra pair of exhaust clamps and bought some stainless exhaust tips (cheaper than buying a length of s/s pipe)
A couple nights of welding, and it's done.
I made one tube 22" and one 26".
Sound waves are supposed to bounce back through the tubes and cancel the reverberation (drone)
Theory is differing lengths will cancel a different range of droning and tail pipes will act slightly differently.
So results;
Exhaust note is way quieter, maybe even too quiet for a hot rod.
Tested it throughout the rpm range. A lot quieter. It even sounds like a different car.
Okay the drone test.
Took it up a few hills thursday night. 4th gear, 3rd gear... loaded up at 1800-2200 rpm... no drone.
Today took it up the same freeway hill as the previous weekend. No drone. It's gone.
The way I built it, I could simply unclamp the tubes and cap the tee if I liked.
I located the tubes across in front of the fuel tank, where the traditional cross flow muffler would go on a mustang.
I am still getting a little rapping from the tri-y headers, and may try the summit collector screens. I think this is due to the header design.
Now I can listen to the radio and low volume on the highway.
A couple pics in the journal
Old 03-08-2009, 01:42 PM
6426yy's Avatar
Funny, I removed the resonators from our 06 Charger R/T. I personally like the sound. To each his own, glad your happy with the results.
Old 03-08-2009, 06:08 PM
Ripped's Avatar
Okay heres a couple links from othe guys who tried this;
Newer mustangs
Pick up trucks
and I am not talking about loudness nor about inline resonators, which would be inserted within the exhaust flow.
This is all about the drone that occurs, usually when the engine is under load or partial load. This seems to happen about 2000 rpm on most V8's.
Old 09-10-2009, 08:04 PM
Ripped's Avatar
Update on the resonator tubes
I found that sometimes the beast was a little too civilized.
I decided to install electric cut outs on the exhaust resonator tubes that I made.
The result, at the flick of a switch I can be loud or quiet. It gives a good example of what these two tubes teed off the tailpipes actually do.
Video with electric cut outs
more explaination in the journal
Old 09-10-2009, 11:01 PM
Newer mustangs
Pick up trucks
2275-2350 on my x piped straight piped Chevy
Shane
Old 09-12-2009, 07:26 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
1800-2000 on my 96 Impala SS
Old 09-12-2009, 08:46 AM
Putting in an H-pipe right before the rear mufflers would had the same effect. That is, if there is room for the H-pipe. A rear mounted H-pipe works great on 70's vettes to stop that low rpm drone.
That same dead-end-tube trick is done with intake piping systems.
quiet powerful cars is the way to go. good job. It is never too quiet.
Old 09-12-2009, 09:26 AM
You will notice that many new cars have exactly this configuration on the inlet tract. Now you know why.
Old 09-13-2009, 12:01 AM
Ripped's Avatar
Lots of great information... Thanks guys.
I wish that I had this knowledge earlier on, I maybe would not have had to replace the 14" magnaflows with the 22" mufflers.
It would be fun to be able to vary the length of the resonator tubes to "tune" the exhaust note.
I notice now, with the collectors making a 4" tee on the tailpipes, before the electric cut offs, the exhaust has a very harmonic sounding note.
Old 01-13-2015, 02:40 PM
Originally Posted by Ripped View Post
So here goes.
So results;
so WHERE did you weld these tubes on? I have the same issue on my highboy 30 coupe hot rod with 350 chevy v-8, over the frame headers and exposed exhaust. I made a couple of these resonator tubes but in a quandry where to put them in the system. My choices are either in the end of the header collectors, or in the tailpipes after the mufflers (which are welded to a slip-on collector ring) . a prompt reply is most welcomed
Old 01-13-2015, 03:21 PM
OLNOLAN's Avatar
Helmholtz resonator
I've done a little bit of reading on this in the past. Typically I believe they are located at the end of your exhaust pipes, in parallel. Google helmholtz resonator exhaust, there is alot of information on the subject. Nolan
Old 01-14-2015, 01:13 PM
ogre's Avatar
the 'Duracell Project'
old thread but still pertinent information for drone...
as olnolan suggests, Google helmholtz resonator exhaust and look at some of the pictures
we have a couple of exhaust systems that incorporate the helmholtz resonator
you can do the calculations, but some of it is trial and error on the length or volume
look under the hood of any new car and you will see funky plastic boxes on the cold air intake
they appear to be nothing, but accomplish the same thing in the intake
this is the focus tip, we removed a virtual suitcase that weighed 40 lbs and went sans muffler
oem focus exhaust
this is the new chevy ss with a small muffler with the sound tube ahead of the mufflers
i'm always amazed at the size of oem stuff, 10 camaro suitcases here
The Following User Says Thank You to ogre For This Useful Post:
AutoGear (01-15-2015)
Old 01-14-2015, 02:57 PM
454 Rattler's Avatar
NEVER SATISFIED !!
oem focus exhaust
Holy Chit !! All that crap is under a new car ?
They paid someone to design that just to reduce noise. What a waste of time and money.
You might have to take out a loan to replace it in a few years.
454 RATTLER
The Following User Says Thank You to 454 Rattler For This Useful Post:
2.8L s-10 motor with 4.3L throttle body catscan4free Engine 20 04-22-2009 03:12 PM
Exhaust System Sizing RustoRod Engine 88 03-06-2009 09:09 AM
Exhaust tips CrazyRoyExhaustfreak Engine 0 10-29-2006 06:04 PM
Engine vibration at around 2000 rpm fumplet Engine 1 02-20-2006 12:19 PM
4.3L will not run above 2000 RPM 2000blazer5speed Engine 6 06-11-2004 04:54 AM
