I don't know what to call it... - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2011, 03:47 PM
Camaro820's Avatar
something weird happens to my engine. its a 383 stroker from Blueprint and when it gets hot, it sounds like as if air is being released at the compression stroke. i don't feel any change in performance because it has always done it from what i can remember. it's just annoying. no way i could look into now because of the harsh northeast ohio winter; something i will have to look into when spring hits. again, it isnt hurting the engine from what i can tell it's just annoying and something i like to get rid of. a buddy of mine told me to tighten the spark plugs a little more because something similar was happening to him and all he did was tighten them up and problem was solved. i did the same thing in the fall and it's still there. any thoughts?
Old 01-16-2011, 05:18 PM
DoubleVision's Avatar
Bad header gaskets? Broken spark plug? Hole in the header?
Old 01-16-2011, 05:55 PM
Camaro820's Avatar
well, i know its not the spark plugs or headers because i did have a hole in my first set of headers, called hooker and they gave me another pair because it was a manufacturing mistake. and i know its not the spark plugs because i just put a new set in after fouling out the previous set. i would have to check the gaskets because i always seem to have a decent leak.
Old 01-16-2011, 06:55 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Post a video so we can hear it.
Cole
Old 01-16-2011, 07:10 PM
Camaro820's Avatar
check back tomorrow and i will post a video. car doesn't like to start in this cold weather.
Old 01-16-2011, 08:28 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
spray around the area you think its coming from with a squirt bottle of soapy water
Old 01-16-2011, 10:26 PM
What type of cooling fan do you have?
Have you done any kind of compression test?
Old 01-17-2011, 08:22 AM
bigdog7373's Avatar
Of course it's fast
I think i know the sound you're talking about. Its probably and exhaust leak. Is there any flex pipe in the system at all? It will make a similar noise at medium to full throttle.
Old 01-17-2011, 04:22 PM
Camaro820's Avatar
wouldnt soapy water just evaporate when it hits the engine or exhaust? and the cooling fan is a stock setup. that actually does hit the shroud just enough to make a noise, but that is an isolated sound. but no i havent done a compression check. i cant believe i didnt think of that! DUH! and big dog, i want to lean towards your theory. i hope its just an exhaust leak because i cant ever get that thing i stop leaking. i even used the copper gaskets and they still leaked! oh the joys of being a hot rodder... yes? and sorry guys for no video yet. i couldnt upload one onto my computer. im pretty dumb when it comes to computers haha.
Old 01-17-2011, 04:26 PM
& matts38chev
spray bottle with soapy water is how i used to find leaks in exhaust, headgasket, and turbo systems,etc. try it, it works good to find stuff when you cant nail down the exact source
Old 01-17-2011, 04:30 PM
Almost all motors have a certain amount of blowby . all the motors i have ever built 'marine -auto' will hiss at you when you spin the motor over by hand . but the ' when its hot ' is a good one . i would do a comp test and if you find a suspect then do a leak down , if you find a valve thats leaking then back off or take off that rocker arm , if its still doing it then you have a valve or seat issue . no big deal unless its going bythe piston .
Old 01-17-2011, 04:31 PM
Camaro820's Avatar
well, thats a trick i will probably use on more than one occasion for sure. thanks for the tip!
Old 01-17-2011, 09:30 PM
carb cleaner
for on top of the engine a small squirt of carb cleaner or either will idle the engine up if the leak goes both ways! never spray either or carb cleaner directly into a running engine. unless you just love doing valvetrain work
Old 01-20-2011, 09:59 AM
Camaro820's Avatar
i will be posting a video of the sound later today. hopefully the camera can pick it up. sorry for the delay guys!
Old 01-22-2011, 12:10 AM
Camaro820's Avatar
6ft6at66=just call me JD, Jer or Jer D 6ft6at66 Introduce Yourself 1 04-07-2007 01:30 PM
so, call me stupid but.... Nightfire Hotrodding Basics 20 10-20-2004 11:16 PM
Prank call gone bad Kevin45 Hotrodders' Lounge 5 08-24-2004 11:23 PM
What do you call this? Magikal Engine 7 01-19-2004 09:51 PM
