I finally figured it out!!!!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2008, 02:32 PM
71haulnazz's Avatar
My mystery block casting number GM 39700 4 and the suffix code TO521CKA. IT IS A 350. I called the tonawanda engine plant and they never produced a 305 in that plant. It came outta a 72 camaro they forgot the 1 in between the 0 and 4. i guess if you look real close you might see a very small 1 they had to hand cut in with a die grinder!!! If you ever question your block this is the best place to come by far. Alot of knowlegable people. If you can figureout where your block was made call, they will have the answer!!!!! GM has a dept in every engine plant that tracks them.
Old 09-16-2008, 05:33 AM
redlightning's Avatar
Good to know.Thanks
Old 09-16-2008, 09:23 AM
Knight_4000's Avatar
huh, I didnt know that...
That could be usefull infromation as I have several unknown blocks laying around here.
Thanks! and nice work!
Finally Clear! Rat Rod and Ratty Rod!!!! Not A T 25 Hotrodders' Lounge 16 08-31-2007 06:37 PM
Ford 351c Facts Finally Revealed KULTULZ Engine 1 01-10-2007 12:10 PM
Finally Fixed High RPM miss on the S-10 TurboS10 Engine 7 05-24-2005 06:40 PM
Finally painted the Vette! Pony Body - Exterior 2 08-18-2004 04:32 PM
Finally Got A Car!! crazygutgut Hotrodders' Lounge 16 04-19-2004 09:39 PM
