I fixed it! :) but now having trouble with lights - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2009, 11:34 PM
Kayleme's Avatar
Well i fixed the starting problem on my 83 ford kinda but it's good enough. i just by passed the key and put a push start on it. i know that's cheating but i didn't know what else to do. The main thing is i fixed it. Me, by my self and who says a girl can't work on trucks.
ok now that i've bragged alittle i have another problem that i hope yall can help me out with. when the truck is running and i turn on the head lights it stops running. and no i didn't touch the lights when i was doing the starter thing (My husband already asked me that like 100 times) could this be the alternator or the battery? when i take the batt cable off the truck stays running. I would greatly appreciate any help. Thank you!
Old 08-13-2009, 05:49 PM
Saitek5678
saitek5678
unplug the headlamps and see what happens when you turn the switch on.Let me know
Old 08-13-2009, 06:22 PM
Kayleme's Avatar
thanks so much for the help but I went ahead and took it to the shop today. I went to drive it to town and it started spewing oil out the bottom. so i just drove it on over there. but i wish i wouldn't have because it was something that was easily fixed. I just didn't look at it. I figured oil spewing would be something major. any way they r going to fix what else is wrong with it too or at least try. any way thank you very much. I'm sure i will be on here again with problems with it.
Old 08-13-2009, 06:27 PM
Saitek5678
saitek5678
You go girl! and may your truck also! LOL Keep your chin up!
Old 08-15-2009, 09:01 AM
Well, I had to ask my brother being I know jack crap about this subject. This is what he said....
First NEVER remove the battery cable on a car with a alternator with the engine running, that can be done with a generator because the regulater will control charging but an alternator can put out a 100 volts without the battery load and fry your computer, radio and blow out light bulbs and fuses will not protect componets from high voltage only amps, you can also blow your alternator out. On the starter problem, fix it correctly, it was nice that can now start the truck but the problem is it can start anytime in gear! someone can get hurt, the circuit runs through a safety switch that you have by-passed. This latest problem is most likely a bad ground between the body and the battery, look for loose or missing ground straps. It can also also have a weak fuseable link or bad connection in the wiring where as when the headlights are turned on it draws all the power and nothing left to run the engine. This can all be easily checked by an electrical shop.. Russ
Front Parking lights stay on 2004 Impala 47chevy Electrical 5 09-27-2009 05:46 PM
Parking lights from Turn signal lights 32chevy vett Electrical 7 03-30-2007 06:46 AM
voltage to tail lights vs brake lights? stratt134 Electrical 12 06-10-2006 06:51 PM
Need some opinions on tail lights Bluepen Body - Exterior 5 06-29-2004 08:57 AM
Wiring Tail Lights & Turn Signals horvath Electrical 15 04-30-2003 05:04 AM
