I fixed my possi. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2007, 08:48 AM
ElCa/monty's Avatar
I fixed my possi.
Hi all after i destroyed my auburn possi last week i was sitting around talking with a few buddy's and i was telling them how my 10 bolt in my Trans AM with the same slicks held up to 4 years of hard pounding with and without slicks and it was still going strong when i sold it.
then it hit me i remembered i had the ten bolt from my old monte carlo in the back yard somewhere.
so i went out back and found it then brought it into my shop and pulled it apart and had a look at it and it was in great shape.
so i checked everything and it was the same so i tried it and it fit perfect.
i put the cover back on and filled it with castrol syntec and and some possi lube backed down the drive way and went around the block (with open headers) my neighbor's love me.
after that it was test time.
heres a pic of the results.
Old 07-11-2007, 11:26 AM
Greg T's Avatar
www.krusinklassics.net
I fixed my possi.
Thats great. It's much easier to catch hombres with a good working possi.
Old 07-11-2007, 10:10 PM
"I said possi, dammit!" -- L. Ranger
Old 07-12-2007, 01:11 AM
ElCa/monty's Avatar
now thats funny if you cant laugh at that then theres somthing wrong.
Old 07-12-2007, 11:01 PM
Jmark's Avatar
That was funny!
On the right side of the picture, the darker marks are different lengths, are you sure it's working ok?
Old 07-13-2007, 07:42 PM
ElCa/monty's Avatar
if you look closely you can see the different sets of tracks the dark one is from useing the line lock and the others are from just dumping the clutch.
also i had more air in one tire then the other one.
thats why the right is dark all the way when the left is just on the outside
also some overlap each other and it hard to tell whats what.
but its fine.
i tried it on the highway the other night and it was even all the way.
problem fixed strokerchevyII Engine 3 02-02-2005 07:14 AM
10 bolt possi unit 71chevelle406 Transmission - Rearend 1 11-17-2003 10:06 AM
Fixed Steel Bladed Fan Info sixty5 Engine 1 07-15-2003 10:39 AM
On average, how much does it cost to get rust fixed? '54-Hunter Body - Exterior 1 03-07-2003 09:49 PM
8.8 rearend bent (can it be fixed?) shagginwagonvic Transmission - Rearend 2 04-11-2002 02:40 PM
