My chevy truck, I purchased a new printed circuit from LMC becuase the old one was roasted and the dash lights were not correct. If I turned on the left turn signal the high beam would blink, stuff like that but more crazy stuff, trust me.
Well installed the new one and still the same thing, sucks.
All the outside lights have corporation, high beams work, headlights work, turn signals work, back up lights work and none of the outside lights are less dimmer than the other..
So, I'm stuck and have questions, I believe I maybe looking at a wiring harness but wonder if I could just rewire inside the cab?
But, I need something simple to install, something I can read and says use this color here and so on and so forth. Pictures would help too and don't know where to get that, only see wiring kits hsve this. Unfortunately they are not cheap BOO!
I seen a summit highway 22 harness for $400 bucks, I see painless harnesses for under $600 bucks but man I'm not sure what kind to get, hate to over pay for something that I only use 60% of?
If you guys have time for any advice on products that are easy to install or some other way I can get this done let me know.
I obviously want to pay as less as I can but know you can't always do that becuase you'll regret what you paid for.
Here it is, 1980 chevy c10 350/350 trans (plan to slide in a 700r4) 2wd, auto but I think it has a 82 or higher steering column.
I want my outside lights, inside lights, and plan to add air condition later. Will put in a radio system. So to me basic stuff. Guages I plan on are factory from LMC, will add a tach later as well, Just going to go old school on the truck, you know the look of 1970-1980 so nothing fancy on electric.
I hope i made sense and if not just ask away, I'll try to explain but I'm green on electric but not a fool. I'm green enough that I have never used a ohm meter.
Appreciate any feed back guys.
