I got brake problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-30-2009, 10:13 AM
I have a 86 chevy c-10 and when I press on the brake pedal it has alot of resistance.....I have to really press on the pedal to get the truck to stop. Can this be my master cylinder???
Old 07-30-2009, 10:26 AM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Have you had to do a real hard 'panic' stop? I have had a couple of customer's do this, and they both had blown power boosters. The master cylinders, and the rest of the brake systems were fine.
One was a '89 C10, and the other one was a '96 Yukon, both are 2WD.
Old 07-30-2009, 10:42 AM
not quite a hard panic stop but I've had a couple close calls....thanks for the info....how do I check the brake booster to see if its good or not??
Old 07-30-2009, 10:53 AM
My 2 cents worth
Wiki Edits: 3
Pull the check valve out of it, you should hear a 'hissing' sound, or you may hear a vacuum leak coming from under the dash when on, or off of the brake pedal.
Also, with the check valve pulled, try sucking, and blowing through it. It should only work one way.
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
Advices on brake system repair 78 Monte rack Suspension - Brakes - Steering 5 01-12-2009 08:32 AM
94 GM Suburban Brake Problems DV8 Suspension - Brakes - Steering 3 02-02-2007 07:47 AM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Brake problems... gemini86 Suspension - Brakes - Steering 5 10-06-2004 07:06 PM
